Totaline Thermostat My thermostat is in the "LOCKED" mode and we have tried everything to get it unlocked. I just moved in and I have no manual.
  • 5 more comments
  • Anonymous May 21, 2008
    I have a totaline thermostat model P374-1100 it is in locked mode what can I do
  • Anonymous Aug 12, 2008
    mine has no power to it. i checked the breaker.... any suggestions?
  • keckhardt Oct 06, 2008
    My Totaline PV110 programmable thermostat just froze up - any suggestions on what model is a better replacement>
  • Anonymous Oct 09, 2008
    same. EH is showing but none of these suggestions work.
  • lakhubhai Dec 11, 2008
    I have Totaline P474-1010 Thermostat no power. It was working and I took it out of the base and drop it to the ground. Cannot see any physical damage, not even any scratch. Any suggestion
  • Anonymous Jan 05, 2009
    Press the MODE UP and DOWN buttons all at the same time... and hold until the Locked goes off
  • Anonymous Apr 25, 2009
    Had the "EH" pop up where the AC temp should be. Just held the fan button & while holding the fan button, I pushed the up button & presto! Got my AC back! Theres no living in Florida with out AC!
  • 3 Answers
If you see a EH where the cool temo should be, press mode and the Up button, and you will have AC
Posted on Oct 10, 2009
Hi, My totaline thermostat says EH on it and will only heat. No AC. any suggestions. Previously my AC repairman came out and added Freon into the unit. But did not fix it totally either.
Hot In Atlanta
Posted on Apr 26, 2008
Press the mode button, the up botton, the down botton all at the same time, and presto, now remember, all three buttons at one time
Posted on Oct 04, 2010
How do I get my totalline thermostat to cool it will not go down when I press the minus sign? I don't know what model it is
Posted on Oct 12, 2009
My thermostat has a equipment reset button on the circuit panel. Remove the thermostat from the mount, then push the button with your finger. You will need to reprogram your winter and summer settings. Give your Climate system time and it should start working within 15 minutes.
Posted on Jan 08, 2011
A totaline thermostat "stuck" in locked mode can be unlocked by pressing Mode, and the up and down buttons at the same time. You might have to hold them for ~ 10 seconds. These thermostats are junk!
A totaline thermostat that displays "EH" is in the "Advanced Programming" mode. Press Mode and then press and hold the round button beside the mode button (either fan or override) for about 10 seconds. This will get you out of "Advanced Programming" mode. You should download a Totalline manual from thier website.
Posted on Sep 18, 2008
Press and hold the fan button and while holding press the up button
Posted on Jul 19, 2008
  • Feuza Reis
    Feuza Reis Aug 26, 2013
    thank you, this worked
Your problem is registered with NETWORKING HUBS and SWITCHES PROBLEMS in computers. I take it that your thermostat is not in a computer? (kidding). have you tried a hammer? (kidding again).
Anyway, it needs opening up if it's the kind that do. Some older ones can be opened and cleaned out. Some burn out and freeze. It's one of those things. Getting a new, more efficient one is often cheaper and saves on power. Digital ones are more acurate and great.
What d'yu wannta do?
Let us know.
Posted on Feb 27, 2008
How to I control this ridiculous thermostat (Totaline P310-0210) Just moved into this house and no manual, if I press buttons it says stage 1 or stage 2, I/m freezing...someone help!!
Hello Stephanie Sakata,
I found 2 (two) "TOTALINE" manuals...
These little beauties all work pretty much the same...
Put the slide switch in HEAT MODE...
Push the "HOLD".. (which keeps any/all
clocks/gadgets and BACK-SETS off)...
and ADJUST THE TEMPERATURE where you want it...
ELSE...
Read these manuals (
close)...
No exact matches found Try these results
Carnac the Magnificent
Dec 13, 2017 | Heating & Cooling
Press and hold mode. While holding mode press program. This enters setup menu. Option 13 is security. You want 0 in option 13...no lock. If this doesn't work I need model number.
May 25, 2017 | Heating & Cooling
Thermostat Totaline P7470100
It's probably the liquid crystal has a crack and is flowing inside the glass. It can only be repaired with a new display.
Why not contact Totaline directly and see what they can offer?
Contact Us Totaline
Jul 21, 2016 | Heating & Cooling
How do I get the thermostate out of the Hold mode?
[PDF]Troubleshooting Common Thermostat Problems - Totaline
https://www.totaline.com/dl/troubleshooting_signature_star.pdf
When the temperature limit is exceeded, the furnace shuts off the burners ... buttonthermostats, hold Mode and Fan (or Mode and Override) for SEVEN seconds.
Sep 25, 2015 | Heating & Cooling
I have no idea how to use my totaline digital thermostat,
Totaline is a brand name of the Carrier Corporation. Go on www.totaline.com and research the model of your thermostat. User manuals are available.
Nov 11, 2013 | Heating & Cooling
I have a totaline 0441...with an EH error code I can't seem to remedy any help?
It sounds like your thermostat is stuck in EMERGENCY HEAT mode programming. To Exit,
Press the FAN button. While holding the FAN button, press the UP button for 2 seconds.
I'm also attaching a link to the manual for your thermostat.
I hope you find this information helpful to you.
http://www.totaline.com/dl/P474-10101ForAllProgrammableDigitalThermostat.pdf
Mar 13, 2010 | Heating & Cooling
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Computers & Internet Logo
10,836 people viewed this question
David Payne
David Payne
