Question about Jabsco v-flo water pressure pump - 5gpm - 12v
Water pump will not turn off
Jabsco v-flo 5gpm pump will not turn off. Starts fast and slows to a slow pump. Rep at Seattle Boat Show thought it was defective. There are no leaks in system and only one faucet at this time.
2 Suggested Answers
rvanderbr802
SOURCE: Have a Jabsco Self-Priming Macerator
Try removing the plastic cover, from the motor and turning the shaft that extends out the back of the motor. I used pliers and the macerator is working, now. My problem was that a pebble had jammed the impeller. Turning the shaft freed the pebble from the impeller.
Posted on Dec 16, 2013
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Jabsco toilet fails to fill
Was the toilet "Winterized" last fall? If so, have you assured that any plug in the clean water intake has been removed? If NOT -- are you sure the pump has not been frozen and internally damaged by ice? The pump is a simple device which rarely fail unless its inlet is blocked, or the pump seals or body are damaged - usually by freezing.
May 10, 2014 | Jabsco 29120 2000 Marine Manual Marine...
Lowrance hds 5
I would imagine it might have something to do with water turbulance? Do you have a sensor thats located at the bottom of the boat somewhere? In my grandpas boat, the sensor is at the rear bottom near the hole where you can drain the water, if your going very fast it doesnt work very well, slow or stopped and it works fine. If you have that type of sensor make sure whatever holds it is tight so the sensor cant move around.
either that or you got some funky wiring issue lol
Nov 01, 2013 | Lowrance Hds-5 GPS Receiver
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
I have a 1 hp power flo matrix. When I run the pump without water on a bench it runs fine. I put the hoses back on and run it, it starts slow never kicks into full power and trips the braker. Any thoughts?
It sounds like something is causing the motor to not only have limited torque but also draw more than normal current. It sounds like a problem in the motor but exploratory surgery would indicate the cause for sure.
If you are not wanting to turn wrenches yourself then my best suggestion is to bring it to Leslies Pool Supplies and they often can put it right for the price of the parts while you watch.
I hope this helps.
Sep 18, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Jabsco v-flo water pressure pump - 5gpm - 12v Logo
24 people viewed this question
Top Jabsco Plumbing Experts
Gil Shultz
ray gallant
Are you a Jabsco Plumbing Expert? Answer questions, earn points and help others
