I push the switch, I hear it click, there is power draw because the room light dims briefly, just like when it used to turn on, but nothing happens beyond that. Every time I push the switch, same thing.
SOURCE: Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
That your amp does not go into the second stage of powering up indicates a fault which is causing it to sit in non-active mode. This could be due to blown output audio module or transistors or a fault in the safety circuit itself. It is not a fault the non-technician can repair and it would need to be sent to an authorized workshop.
I have seen situations where users unknowingly leave frayed ends of wire shorting across the speaker output terminals which can lead to this sort of fault. You could check this out also.
