Open samsung syncmaster - Computers & Internet
732nw
k open it from the top side
Aug 27, 2012 | Samsung SyncMaster 732NW,SyncMaster Magic...
How to open CRT samsung Syncmaster 753s. I tried to open, it have only two screw, i removed that, but not able to open it. reason behind to opening, some noise is comes as same as short ckt.
its easy actually..there r two locks on top of monitor. u can see minute space betweem backcover and front...insert any thin bt hard strip or pin and push them back simultaneosly pull back the cover.it would work
Aug 27, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
I want to ask how to open case on SyncMaster SAMSUNG T200 monitor 20'
Its sitting around snapped first remove the hoof and look for some screws to find open with a putty knife or very flat tool, but beware the cap has tabs that must be slowly loosened otherwise they will break.
Aug 26, 2010 | Samsung SyncMaster T200 LCD Monitor
SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
How do you open up Samsung LCD 740N monitor?
This monitor contains a latches to open. Its recommended that you use suitable tools and service manual.
If the unit is in warranty its recommended that unit to be serviced by service Engineer.
Dec 21, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
How to open monitor samsung syncmaster 753s?
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Aug 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
How to open the back cover of Samsung SyncMaster 794mg CRT .
Apr 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Syncmaster 214T
http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
May 15, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
How i open my vx900 lcd monitor
sir
give full detils about your Product and copany plz after then i give ans Mail : uday_uday2004@rediffmail.com
Apr 02, 2008 | Samsung SyncMaster 152 B 15" LCD Monitor
Removing the back cover of a Samsung SyncMaster 753s
there is 2 lock on front side first remove back side lock or scrow then insert small pin pull up back cover your monitor will get open
ashok
Jan 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
