Question about Samsung SMH9187ST Microwave Oven
SMH9187ST runs but doesnt heat
Cooked a plate of bacon (no issues), went to cook a second plate and it wouldn't cook. Everything else appears to work (light comes on, counts down, table turns, can even hear the "humming" of the magnetron). Doesn't heat (sometime barely heats) food.
MicrowaveSvc
  • 9047 Answers
SOURCE: Not heating food
While it's possible it could be a door switch or mount, it's most likely a bad magnetron or a bad connection at the magnetron or on the control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Samsung models here: http://www.samsungparts.com/search/search.asp
Posted on Apr 25, 2007
heatman101
  • 43501 Answers
SOURCE: samsung mw87L microwave does`nt emit heat, light
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhj
Posted on Sep 30, 2010
2coolrick
  • 560 Answers
SOURCE: My samsung microwave oven is
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Posted on Oct 03, 2010
  • 6771 Answers
SOURCE: the microwave will not heat food. It will turn on
This seems to be a common problem, there are three parts that will cause this, the magnetron "heats food" a common failure, the high voltage diode and capacitor are the other two culprits. The cost to repair will approach the price of a new oven.
Posted on Feb 01, 2011
  • 184 Answers
SOURCE: The microwave does not heat
Hi!
The most common cause of the problem you described is a burned fuse. It is normally located inside the case, directly on a wire leading from the transformator to the magnetron. If you are not sure about those parts, please get a professional to fix the issue.
Posted on Aug 20, 2011
Why does my. MAgic Che f microwave smoke inside when I cook bacon?
Although bacon can be cooked in a microwave, cooking any low water content food is ******* an oven, and can shorten the lifespan of the magnetron.
The smoke you're seeing is probably from the grease in the bacon. However, there's a slight chance it's from the power transformer as these sometimes fail slowly. You should be able to tell from the type of odor.
Aug 11, 2017 | Microwave Ovens
Small amount of white smoke coming out of kenmore convection microwave in oven mode
That is usually caused by a build up of fat from microwave cooking on the heating element. It will clear under normal conditions and return if one cooks foods like bacon etc, un covered to prevent splashing of the food that is being cooked.
Hope that helps.
Oct 31, 2010 | Kenmore 63793 Convection / Microwave Oven
The glass turntable broke in 3 pieces this morning while cooking bacon. The bacon was not yet cooked or even hot. It broke into 3 large pieces. The unit is not at all new. Does this sound normal? Did I do...
The same thing happened to my microwave this morning while heating a cup of water, which broke into 3 pieces too before the water hadnt even hot.
Maybe you have already solved your problem and I just share my experience.
I am trying to call the manufacturer nearby and ask for the turntable, but I am afraid the new turntable dosent fit my a little bit old microwave.
Dec 27, 2009 | Microwave Ovens
The microwave was cooking, a few seconds later it ceased working
If it's not making a strong buzzing sound or anything out of the ordinary, it's probably the Magnatron. Most of the time that's what I find. It's the "antenna" that creates the microwaves. Some ovens carry a 5 year warranty on that part so I would check your manual. They are very easy to replace most of the time. They usually run about $100-$150.00
Feb 15, 2009 | Microwave Ovens
It don't heat anything any more. power is on turns counts food doesn't even get warm. i bought this unit from wal-mart in Joplin Missouri. 4/18/08 Wal-mart will not help me because it out of there 90 day...
one would surely assume that a product would last more than 5 months. of course you know not to put metal in a microwave, so the real question is, have you ever cooked bacon in it? I can assure you that this is a very bad idea, as the grease gets sucked up into the fan and distributed all over the sensitive circuitry inside the unit. mine actually caught on fire while cooking bacon, so now we are back to the skillet. in conclusion, the micron is probaly fried in it and it is not worth fixing. chunk it and get a new one.
Sep 11, 2008 | GE Microwave Ovens
Ge JVM1190 appears to be working but does not cook.
I spoke with a qualified microwave technician who advised me to buy a new microwave as the problem I was having indicated that the magnetron tube had blown. What a waste of time to ask for help from you.
Sep 01, 2008 | GE JVM1190 Microwave Oven
MICROWAVE WON'T HEAT OR COOK
Sorry if you misunderstand, but I offer free advice so you or someone you know can fix things yourself.
Chances are you have a bad magnetron or other high voltage part, but I won't bother you with details now.
You take care of yourself.
Jul 19, 2008 | Microwave Ovens
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Samsung SMH9187ST Microwave Oven Logo
41 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
