Question about Olevia LT37HVS 37 in. LCD HDTV
Picture size Picture is a 13" square...not filling the large screen we have (children hit buttions) can't get back to normal beautiful full screen size. Help!
  • RWiley Nov 25, 2007
    Aspect ratio is set to full screen but picture doesn't fill screen on Non-HD channels. Why?
They may have gotten to the zoom function. There is a zoom button on the cncealed part of my remote. Hit the zoom button to cycle through all the screen sizes.
Posted on Nov 17, 2007
Ad? Turn off "store" or "display" mode in menu. Look for picture size or "aspect" in menu. Remote should have button for "Size" or something.
Feb 12, 2014 | Vizio Televison & Video
LG 55ln5700 picture does not fill screen
Go to picture/video settings and make sure your screen size is set for 16:9 or wide screen ratio.............
If you have dish or cable go into menu settings and check and make sure the same is true
Sometimes on the remote there is a picture size/mode button you can press to change the screen size
Normal or Wide would be widescreen
Stretch is zoomed picture that fills the screen
Letterbox is the square box screen
It sounds like a picture setting problem to me
I would try those things first
Jul 09, 2013 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
TV AudiVox tv has Small Picture about 2inch in size in the middle of TV Picture is not full 13 inch Screen.
hit your TV lightly on left side or right side or on top & then observe will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other contact good TV service engineer
Apr 19, 2011 | Audiovox AVT-1475 13" TV
Dell Inspiron E1705 laptop, my screen was full 17" but now its like 13" viewing area? What setting changed and how do I put it back to normal viewing?
There must be a key called "fn" in your keyboard. Hold on it and press the square indicated key in the f-keys at the top. You have shrunk the screen size. This must reset it.
Jun 19, 2009 | Dell Inspiron E1705 Notebook
Picture to large for screen
hit your aspect button or fomat button on your remote it will adjust size of picture also verify cable box aspect ratio
May 08, 2009 | Televison & Video
Picture in high def does not fill screen
That is normal. Most HDTV's have a format or picture size option on the remote or menu. It will give you options like full, stretch ot zoom to fill in the blank spots. The problem is those settings can also distort the picture size so people look funny.
Feb 28, 2009 | Protron PLTV-37 37 in. LCD Television
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Olevia LT37HVS 37 in. LCD HDTV Logo
171 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
