Question about Titan 440i Transducer Assembly 704-251 Paint Repair Part Authorized Service Ctr
How do I replace transducer in my titan 440i sprayer
4 Suggested Answers
  • 5 Answers
SOURCE: Titan 440i wont turn on....
Your Transducer is shot the 440i has had this problem since inception. Now they are getting part made elsewhere. Your 440i has a four year warranty. it is covered the part if you dont have warranty cost 85.00 US. It is not a hard thing to replace on your own about 12 min. and your set.
Sincerely Steve Winters
Posted on May 29, 2009
  • 885 Answers
SOURCE: 440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Posted on Jul 19, 2012
  • 885 Answers
SOURCE: i have titan 440i and it has very low pressure when i swich it from prim to spray keeps running
When you switch it from prime to paint and it's still running:
- If paint/water continues to come out of the prime tube, your prime valve isn't seating properly and needs to be replaced.
- If you get a little pressure at the paint gun but it is surging, your packings, most likely the lower set, are damaged and letting most of the paint leak back past them. Packing/seal kits are available for your machine. Use all parts in the kit and grease/lubricate all of the parts well. Inspect the piston and cylinder for scoring or pitting that can damage new seals. They should be mirror smooth for proper operation and life of the seals.
Posted on Oct 31, 2012
My titan 440i primes but wont stop in priming when in spray position
I am not very familiar with airless sprayers but try this link to a youtube video...
https://www.youtube.com/watch?v=5DGUHwBmdaM
May 12, 2017 | Air Tools & Compressors
I have a Titan 640i painter sprayer that is older . Made around 2002 . It will not run . The yellow light flashes but the motor doesn't start. The power source is fine. The pressure is turned up.
If the motor fails to start look for a button (often red) on the motor. This is a reset button for the thermal overload protection most electrical motors of significant horsepower are equipped. Make sure the power is off, push the button to reset, then power on the motor. If the motor still does not start check to see that the mator's shaft turns freely. If not, the mator's armature is frozen due to corrosion or melt down. If the armature turns but the motor still isn't starting, another possibility is that the motor's brushes are too worn or have cracked or fallen apart due to age and/heat. Motor brushes are fairly cheap and normally easy to replace. If you're not a handyman consider taking the motor to an electric motor repair shop to check for continuity and estimate for repair. Hope this helps!
Jun 13, 2016 | Titan 440 Impact Airless Paint Sprayer...
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
Piston seal
Hi Agustin,
Sorry that I have not replied before; only just seen your enquiry.
The problem is either the piston seals are worn, in which case paint is likely to come out into the oil cup, or you have a valve problem, either something is stuck in a valve or the valve could be damaged (the seat or ball) Call me at Lion Industries if you need to discuss 01543 251 560
Dec 16, 2013 | Titan 440 Impact Airless Paint Sprayer...
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
How do I clean the filter?
If you are still having filter problems please call us Lion Industries on 01543 251 560
Nov 29, 2012 | Titan 440 Impact Airless Paint Sprayer...
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
Mar 13, 2009 | Titan Air Tools & Compressors
Titan 440i Transducer Assembly 704-251 Paint Repair Part Authorized Service Ctr Logo
100 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
