Question about Dyson Vacuums
My dyson 37 vaccuum beater bar no rotating fast enough it seems to be sticking
chrispurs1
  • 372 Answers
SOURCE: My Dyson 07 beater bar doesn't rotate
Hi.
If your Dc07 is all floors it will have A clutch fitted this is easy to determine just stand in front of your machine look down at the left hand side there will be a coloured knob on the side e.g. blue.yellow,green,purple this will have a pointer on it which when you pull handle back to vacuum must move to drive position you can rotate it by hand if it is stuck in park position ,
If there is no belts broken the brushes will now turn.
If they don’t the chances are one of the 2 belts have snapped.
You will then need Manuals to help you repair the problem.
Go to this site for more infomation.
http://dysonmanuals.llc.nu/
Chris..
Posted on Feb 12, 2008
SOURCE: Dyson Animal dc07 -- change belt
Read the manual -- available on the Dyson web site. Brushbar not spinning • Ensure brush control is set on carpets mode. Note: brushbar will only spin when the handle is reclined.
Posted on Dec 28, 2008
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Posted on Jan 01, 2009
ukvacfan
  • 328 Answers
SOURCE: Dyson 18 slim the rotating brush bar will not
If the DC18 has a proteted belt then it will have to be replaced by a Dyson engineer or repairer. If the cleaner has a removable sole plate where the beater bar is then remove it and replace the belt - sounds like the belt has snapped and needs to be replaced. if your DC18 is still relatively new it should still be under guarantee.
Posted on Mar 27, 2009
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
Right out of the box, the vaccuum has been making the grinding noise indicating that something is blocking the beater bar. There is nothing blocking the beater bar, but the clutch piece appears to drop...
I found the fix for the dc 33. Open up the cover to the beater bar. look at the cover. You will see many small triangles. Look very closely for a small rubber strip that runs along the edge where the triangles are. It is kinda hard to see. Once you find it remove it. Now on the vacuum itself there is another strip. This strip is very similar but a little longer. Remove that strip. No more **** noise whalla. The perfect Dyson!
Apr 17, 2011 | Dyson DC33 Bagged Upright Vacuum
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
DC15 - beater bar is not rotating
There is a tiny motor for the bar itself at the side of the bar you will see tiny slits which is the vent for the motor which is most likely burned out and will need a replacement.
Apr 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Ran across shoe lace and when I pulled it out the beater bar quit rotating
just cut the sholace part that you can see... it will get it into a lot of small peices and just pull out the smaler laces
Jun 02, 2009 | Dyson DC07 All Floors Bagless Upright...
Dyson 18 slim the rotating brush bar will not rotate. Was working fine until I got the edge of a tablecloth caught in the brush, pulled it out ok but now the brush will not rotate fast, but will rotate by...
Mar 25, 2009 | Dyson DC18 all floors Bagless Upright...
Beater bar on Dyson upright won't turn when handle is lowered
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Dyson animal
sounds like you may have alot of hair or thread wrapped around the bar, this can stop it if there is enough, have a look at the beater bar (brush)
Jun 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
14 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
