Question about Garden
Location of oil drain plug on John Deere DP 6000 generator
rylee_smith
  • 8619 Answers
SOURCE: oil drain plug
Hi
It is located on the right side just under the oil tank ; if you follow the rudder hose that exits the rear right side of your oil tank it leads to the bottom of the frame under this is the oil plug. This hose has a plug clamped to the end of it or stuck into a prug that is welded to the frame.
After this unclamp and pull the plug to make sure that you have the dipstick out before pulling it loose.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks Rylee
Posted on Mar 27, 2009
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
SOURCE: gas/oil mix john deere C1200 trimmer
50:1
Posted on Jul 13, 2010
SOURCE: location of Mercedes 2003 C320 oil drain plug
This answer is completely wrong. The oil plug is under the car underneath the second plastic aero panel from the front of the car. Second, the 3.2 litre engine takes 8.5 quarts of oil and not 5 as this will be seriously under filled. Your compter display in your dash will tell you this when it beeps, turns red and reads, add more oil. It also alerts you when the oil has been overfilled because there is NO dipstick on this car. The only dipstick here is the one giving the wrong advise.
Posted on Aug 22, 2010
I have a john deere sx85 (13 hp). Big plume of blue smoke and oil coming out of big air filter opening. Drained excess oil - had fluid in spark plug- pushed out the excess fluid.
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 10, 2017 | John Deere Garden
What is the oil filter part number for Generator engine serial number CD4045C037188?
your number 4045tf258 should be a industrial generator that number is the model number
John Deere 85 KVA 4045TF258 for sale Price 7 359 Year 2005 Used John Deere... notify john deere and use the model and serial number [i have 2 different numbers and are as follows RE506178 Oil Filter 1 RE5 9754;the first should be the new number and the other was the old ] just to make sure of the correct parts number for your unit
Aug 19, 2016 | John Deere 225 325 375 500 650 Alternator...
Oil plug location on John Deere gx85 with Briggs and Stratton 13hp motor
most likely on the left side as close to the frame as allowable
May 23, 2016 | John Deere Garden
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
How to drain the fluid on a 550 john deere dozer
Put on your old cloths and crawl under it . Remove the drain plug and catch the oil in a container If it has a guard plate underneath there should be a hole with a removable plug in it If it is the radiator you want drained there should be a plug or tap under the bottom of the radiator and a plug on the side of the engine block
Oct 18, 2015 | John Deere Garden
Where is the oil drain plug on the sx75 John Deere riding mower
It is not a plug, it is a drain petcock (nozzle) you will need about 2 feet of hose that you slip over the nozzle, then turn the Knurled Knob (brass ?) behind the drivers side rear tire (maybe the passengers side rear tire) It will probably have oil on it and may not be that visible, it is right at the bottom of the engine. Not that fun...but it is easy.
Apr 16, 2015 | John Deere Garden
Cant drain trans oil, gt225
That trans should take 4.2 quarts of John Deere lo-visc hygaurd.With both plugs removed from bottom of trans as well as the bigger black plug on the front side of trans,it should fully drain in about 5 minutes.Dont forget to unscrew the black fill plug from top/left side of trans so it can vent.Your book may say not to remove it but it's a misprint.When you go to fill trans dont install fill plug until oil is at top of threads,then install plug/cap.Continue to fill trans through white plastic tank until its level with lines.
Apr 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Need to change tranny oil in 550 deere is there a drain?
If it is four wheel drive then take the drain plug out of the fwd drop box.If not fwd the there is a plug in the lower part of the differential/rockshaft housing that you can remove.
Nov 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
