Question about Electronics - Others
1 2v emx1300cs ni mh - Electronics - Others
neta
  • 852 Answers
SOURCE: Ni-MH Batteries
The Olympus Ni-MH batteries will provide approximately 200 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are also rechargeable.
Posted on Sep 04, 2005
Quack
  • 542 Answers
SOURCE: Can only Epson brand Ni-MH batteries be used?
I own a variety of NiMH batteries and chargers (both the fast (ie. like the Epson "3 hour") charger and slow or "trickle" overnight chargers for AA applications. As far as I can tell, all NiMH battaries, chargers and appliances (eg cameras) are interchangable. Just follow the Charger Manufacturer's instructions for how long to leave the batteries in the charger. The time required for full charging will be dependent on how much charge is left in the batteries, as well as on the rated capacity of the particular battery used (mAh or "milli amp hours").
Posted on Sep 13, 2005
  • 14 Answers
SOURCE: Energizer 15 minute Ni-MH Battery charger
A flashing red light indicates that there's an error, or the batteries are defective.
No, the unit won't switch itself off once the batteries have been fully charged. The unit will start trickle charging instead.
Posted on Jan 05, 2009
BillB-SA
  • 2761 Answers
SOURCE: low battery icon
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Oct 31, 2009
SOURCE: How can the Panasonic drill Ni-mh battery be rated
13*1,2v=15,6 v. There may even be cells located inside the part of the battery pack that is protruding inside the stem of the drill. Could this be the case here? Battery cells can easily be found on Ebay, although good quality cell are quite expensive. You can also try your local hobby/model-plane-car-boat dealer, which usually have a good stock of battery cells. Make sure it is the type with soldering lugs, and that they match you charger. I.e Nicad vs NiMh vs li-ion and so on
Posted on Nov 29, 2010
My cordless phone Gigaset A49H is working well. I need to replace battery. Can I use AAA Ni-MH 900mAh 2V battery
if the volts of the old batery is the same with the new u can use it...no matters if the old battery was from lithion only or nikelioum / kadmium . u can use nikelium/magnisium batery too all rechargable are (sry for bad english)
Sep 28, 2015 | Siemens Gigaset A49h Cordless Phone...
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
What kind of batteries do I need? can I use duracel Ni-MH rechargables?
The operating manual specifies to use only Ni-MH AAA batteries and warns to not use Alkaline/Manganese/Ni-Cd batteries. Panasonic web site lists replacement batteries at 19.95 for a pair.
Duracel Ni-MH AAA batteries will be fine.
Dec 10, 2010 | Panasonic (KX-TG1032S) Phone
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Camera will not work after Ni-MH and Ni-Cd batteries used
Its not good for the batteries to combine different types but it shouldn't have affected the camera as the voltage they produce is the same. Try a couple of Eveready AA lithium batteries.
Feb 10, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Ni-MH Batteries
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Electronics - Others Logo
54 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
