Question about Zanussi Washing Machines
The washing machine starts, fills with water and then light flashes and thats all
SOURCE: Ariston Washing machine A1636 - Flashing lights
always reset your machine ;turn your dial to the end of the cycle [ the dot] it should flash 3 times quickly, then turn off the machine and on again. then start washing again ...hopefully..worth a try.
Posted on Aug 15, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • 130 Answers
    SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
    check the pump clean out. sounds like something is jammed in the pump
    Posted on Feb 16, 2009
    Mark Harmer
    • 8 Answers
    SOURCE: Washing machine problem
    Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
    Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
    Posted on Sep 21, 2009
    My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
    Some appliances malfunction can be displayed in hexadecimal or in binary code.
    So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
    For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
    " E20 " means "No drain water"
    " E10 " means "No fill up water"
    Dado
    Sep 08, 2014 | Zanussi Washing Machines
    LED lights flashing
    maybe the washing machine is ok . there is something wrong with led light . the switch can't in a good contact .
    home led lights
    May 22, 2012 | Zanussi ZWF1420W Front Load Washer
    Hotpoint BWD 129 machine starts to fill -
    Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
    Feb 12, 2010 | Washing Machines
    Machine fills w/water quits flashes lb? lz?
    There is a water pressure switch that operates when the required water fills in the tub. this pressure switch in your machine is possibly faulty. In ur case the water keeps filling then it detects an error and stops that's when the lights start flashing. the pressure switch fails to detect the amount of water in the drum and so the machine doesn't move on to the next cycle
    Oct 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Wil163 3 lights flash mid wash
    My machine starts filling with water, then the power button and the two next to it start to flash, and the water starts to drain from the machine.
    Apr 12, 2009 | Indesit WA 115 Front Load Washer
    Soon as i set cycle and swich on door light flashes open
    hi,
    The cycle doesn't advance
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    Indesit w93 washing machine fills with water but doesn't start washing
    Feb 26, 2008 | Indesit W 123 Front Load Washer
    Hotpoint Aquarius WD420 5+5Kg
    The water level vacuum switch are not working , check hose might lose.
    Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
    what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
    Jun 20, 2007 | Ariston Technologies AW149NA Washer
    Washing Machines Logo
    15 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
