Question about HP LaserJet 2840 Printer
HP laser Jet 2840
This machine is supposed to read xD picture cards. When I put a FujiFilm M 1gb xD-picture card in the reader, I get an error message "unknown memory card" error. I know the card is good, because I took it next door & my neighbor downloaded my pics to his computer.  Please Advise.
    Problem Solver:
  • 14 Answers
Re: HP laser Jet 2840
Try using a different Memory card and see if it reads it, if not you might need to replace the memory card reader.
Posted on Apr 11, 2008
0 characters
3 Points
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
Mar 26, 2014 | Epson PictureMate Photo Printer
Hp laser jet 2840 Error 59.99
T2 Clutch error: Check the cable
connections to the DC controller. If the error
persists, remove the imaging drum and
check the clutch. If the error persists,
replace the T2 clutch. If the error still
persists, replace the DC controller
May 26, 2012 | HP LaserJet 2840 Printer
The 2355 gives an error when I plug in a SD/SDHC Memory card, it won't read it.
Your HP all-in-one can read the following memory cards: CompactFlash (I, II), Memory Sticks, MultiMediaCard (MMC), Secure Digital, SmartMedia, and xD-Picture Card. Note: It will not read an SDHC.
Jan 21, 2011 | HP PSC 2355 All-In-One InkJet Printer
Hp colpr laser jet 2840 machin showing error 3 .what is a problem
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
please take out the print cartridge
wait for the insert cartridge message to appear
unplug the power cord
wait for 2-3 minutes
plug the power cord back in
turn the unit on and reinsert the cartridiges
check for functionality
Nov 21, 2010 | HP LaserJet 2840 All-In-One Printer
Hp 2840 Laser Jet wil not power on
this sounds like a low voltage power supply issue. your low voltage is soley for powering up the machine
part number RH3-2260
Sep 29, 2008 | HP LaserJet 2840 All-In-One Printer
HP color jet 2840 cartridge not recognize
Turn the printer off and turn it back on again and see if happens now.
Jul 12, 2008 | HP Color LaserJet 2600n Printer
An 80 service error is an MIO error. That is one of the accessories that is in the option slot in the rear of the machine.
  1. Turn of the machine.
  2. Unscrew and remove the Option card.
  3. Slide the card back in.
  4. Power the machine back up.
If the card is an option that ou do not use (such as a network card) You can just leave it out if you wish.
Please let me know if this helps.
Read more: My HP Lazer Jet 5M displays a message 80 SERVICE (01E4). - JustAnswer"#ixzz2Axr0Tbqj
Jun 16, 2008 | HP LaserJet 4 plus Printer
HP Officejet Pro L7680 Problem - memory card reader
You should see in "My Computer" a few drives that read "Removable disk". They refer to the memory card slots on the printer. Double click on each one until you find the one that your card is in.
Jun 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Memory card problem
Hi I suspect this is due to the printer being unable to read this size of memory card, as i have the same problem, where as it will read a 128mb card but not gb !
Feb 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
HP LaserJet 2840 Printer Logo
170 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
