Question about Umarex Surge Xt Air Rifle
Replacing an o ring on a surge xt
Can I use an o ring from the hardware store?
The rubber ring on the screw clousure is very damaged
remove and replace o ring, o rings can be found at hardware stores
press the helpful button and follow me on fixya
Jan 29, 2016 | Irons
The small rubber? ring on the bottom of the immersible bleder is black, and it smell burnt. What can I do? Is there a replacement part? What is the address(e-mail) for replacement parts? Thanks,...
First identify if it might just be an "O-Ring". Some of these can be found at auto parts stores or local hardware stores. Also check for O ring suppliers in your local phone book. Lastly, find an appliance part store near you.
Nov 06, 2010 | Wolfgang Puck Immersion Blender
After a series of power outages and brown outs over the weekend, our system has lost all of the predialed #'s and only one phone in the whole office (10 phone) rings.
Hello. Often the aftermath of a power outage is a power surge. If your phone system is not surge protected, this is the likely culprit. The damage done by a surge or several surges can only be assessed with a thorough diagnostic exploration. This has to be done by a technician with the proper diagnostic equipment and know how. j.
Jun 14, 2010 | Samsung Prostar 816 Phone
Unit will not power up
check fuse in power cord if using in car adapter. unscrew the silver ring at the tip of the cigarette plug DO NOT ALLOW THE SPRING TO SHOOT OUT WITH THE SILVER CONTACT PIECE INSIDE! remove the spring and contact piece then remove the fuse, look to see if it is scorched, you will either see black soot on the glass or a break in the wire that runs through the glass tube. Hold it up to the light. See if you can tell where the brreak is. Sometimes the break is at the verry top and you cant see so just replace the fuse with a new one form the hardware store, ETC. replace fuse spring contact tip and retainer ring then plug in and try again.
Nov 29, 2009 | Delphi Roady XT XM Radio Receiver
Xt cranks replacement. The black plastic
Have a look on this website under the bottom bracket articles:http://www.parktool.com/repair/byregion.asp?catid=61&imageField2.x=19&imageField2.y=8
Nov 02, 2009 | Cycling
Just installed sram pc991 with shimano xt goupset. the chain
Hello
Thank you for using
FixYa for your problem
You have replaced front and rear chain rings too
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Oct 27, 2009 | Sram Pc991 Chain Speed
White smoke when running xt350
this is coolant being burnt check it if ok get back to me
Sep 18, 2009 | 2004 Yamaha XT 660 X
The o-ring for my garden treasure pf 1600uv filter needs to be replaced. Do you know where I can purchase one? tfunk@gorockets.org
o-rings come in all sizes usually in milimeters
any hardware store auto parts store stocks them; just bring the old one with you for comparison
Jun 23, 2009 | Garden
Replacement o-ring
I have the same problem with my Valira expresso coffee maker. If the manufacturer does not supply extra gaskets, as they should, when the coffee maker is purchased, forget about trying to purchase them. Instead, bring the broken seal to a hardware store and find material to use, using the old one as a template. Most hardware stores have assorted sizes of round gasket that can be adapted.
Sep 08, 2008 | Valira Claudia Coffee Maker
Umarex Surge Xt Air Rifle Logo
52 people viewed this question
Top Umarex Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Umarex Optic Expert? Answer questions, earn points and help others
