Samsung rv511 dc jack melted - Computers & Internet
2 Suggested Answers
SOURCE: how do replace the DC jack on a samsung NP300V5A laptop
DC Power Jacks for the most part are soldered onto the motherboard. There are some models where the DC Power Jack and the cable harness just sits in a slot on the motherboard. And there are some models where the DC Power Jack is soldered on a little circuit board that is secured by screws to hold it into place. In any case to get to the Internal DC Power Jack you have to disassemble the laptop. And if it's soldered onto the motherboard, you will spend time unsoldering the old broken Jack before you can install the new one. Get a quote from a local repair shop, then check the guys out at: http://www.generalsystemsconsulting.com They will repair it and ship it back to you via Fedex or UPS cheaper than most quotes you get including the shipping charge.
Posted on Mar 16, 2012
Samsung rv511
Faulty connector?
Dec 30, 2013 | Computers & Internet
Samsung rv511 a03za
Download the guides from the link below to assist.
http://www.samsung.com/uk/support/model/NP-RV511-A07UK-downloads
You can also run the crucial memory check to determine what you need.
Dec 27, 2013 | Samsung Rv511-a01 Laptop
Samsung rv511 webcam driver
Hi nickersgasco
Go to the following webpage to download your drivers from your webcam
Bud
http://www.samsung.com/us/support/owners/product/NP-RV511-A01US#
Oct 12, 2013 | Samsung Rv511
Adapter from power cord gets power, but is not charging samsung rv511 laptop
Step 1:
b> If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 12, 2013 | Samsung Rv511
Smoke, Fire hazard, Samsung Laptop
Check your power brick.
Also, did you replace the power jack or just clean it?
May 26, 2017 | Samsung NP RV509 RV511 RV515 RV520 RC720...
My Samsung RV511 Laptop isn't getting power.
Most likely problem in this instance is a loose dc socket. it is a cheap fix or you can re-solder it yourself, if you have the ability.
Nov 26, 2012 | Samsung Rv511-a01 Laptop
My laptop charging port is not working problem. I have to wiggle it about and selotape it into place for the computer to charge. What do you think is the most likely cause the port its self or the charger?
I think it is because of the loose dc jack. So
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place....
http://www.chargerbuy.com/laptop-ac-adapter/samsung-compatibility.html
Oct 29, 2012 | Samsung Rv511
The needle from my charger broke inside my laptop how do i get the needle out
You mean the charger pin stayed in the power jack? Power jack is very fragile, you'd better not force it out. Take it to a repair company, they will help.
May 08, 2012 | Samsung Rv511 Series Laptop Intel I-core...
I replaced the DC jack on the laptops motherboard because my Charger Fried and also melted the inside of the DC Jack, But not That I have installed a new on the power doesn't seem to come on at all, The...
There is. It would appear that the DC jack was not the only thing that was fried. If all your solder connections are correct, the mother board may have been damaged be the shorting of some part on the board, and burned open. Look for fuses, and "resistors that are have a "0" on them. they should read a short. if you find nothing. the board is damaged beyond repair.
Apr 18, 2011 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
