Question about Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18
What do you set the timer on for the utilitech pro led light
Model number 0174483
My floodlights Utilitech 6211W-PIR23A come ok but will not turn off at night, on test they work ok.
light sensor failed or covered in dirt. or you have set it on double switch that means the stay on. to turn off permanent light flick the power on to the lights on off on. should go back to timer that has been set. 3 5 10 min.
Apr 19, 2018 | Utilitech Pro 180-Degree 2-Head LED...
I need the English instructions for the Utilitech timer #0144506
I found a Utilitech timer at Lowes with the item number #0144506. The Utilitech model number for this timer is UTTNID001. If this is the correct timer, the manual is on the product page: https://www.lowes.com/pd/Utilitech-15-Amp-1-Outlet-Digital-Residential-Plug-in-Lighting-Timer/4740850 . Scroll down and expand the Guides & Documents section. The direct link is currently: http://pdf.lowes.com/useandcareguides/054732817825_use.pdf .
I hope this helps.
Nov 23, 2017 | Hardware & Accessories
Utilitech Pro, model 0595683. Can I use a dimmer with this LED fixture?
It appears, no you can't use a dimmer on these lights. You can try a CFL / LED rated dimmer, but it still may not work
Jan 06, 2016 | Electrical Supplies
I HAVE A UTILITECH PRO 180 #0205881 AND IT BLINKS WHEN ITS ON
Usually when a motion sensor light blinks LED or otherwise it means that the motion sensor is shot. The light itself is most likely good and for whatever reason you got a bad sensor upon purchase.
Feb 21, 2014 | Utilitech Pro 180-Degree 2-Head LED...
My Utilitech Pro will come on, after a few seconds it will blink twice and then will not come on again for several days.
Sounds like the sensor has failed. The controls are supposed to be on the underside, and kept dry.
Nov 24, 2013 | Utilitech Pro 180-Degree 2-Head LED...
I lost my instructions for my Utilitech #0357930 timer. I cannot get it to work; I can set it to start but not stop. Just need some directions. Buttons on it are On, Off, Day, Hour, Min, Enter, Pro
The AutoChron 81000 Programmable Wall Light Switch Timer is identical to the Utilitec #0357930 (AmerTac) TMDW50L. Here are links to manuals for models prior to and as of 2012.
Before 2012
As of 2012
Nov 28, 2012 | Hardware & Accessories
I have a Utilitech one outlet light timer and I can't get it to work! I've never had a problem with a light timer; they're pretty straightforward in how to use them. I set the current time,...
Thank you for including model number.
TM01DHBL is typical analog timer with 1/2 hour segments located around edge of dial.
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#59366
There are no repairs for defective timer: Here are suggestions.
1) Locally purchased timer has longer warranty period since you can buy same timer later and return defect in new package.
2) Top of timer has slide switch. Most analog timers have 2-or-3 position switch that offers override capability. Set some segments, move slide switch each direction, and then manually rotate timer dial clockwise two full revolutions to watch how lamp turns on-off.
If lamp does not turn on-off with switch in at least one of the slide-switch positions, then timer is suspect.
3) Always a good policy to test outlets with cheap circuit analyzer to check for electrical abnormalities that can affect timer electronics.
Since this is mechanical timer with simple electric clock motor, chances are that reversed polarity will not immediately affect timer.
4) Put timer on a different outlet, controlling a different load, and see if problem is the same.
5) Make sure segments are pulled all the way up.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Hardware & Accessories
Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18 Logo
168 people viewed this question
Top Utilitech Pro Home Security Experts
RSole
Tom Chichester
 Russ Hill
Russ Hill
Are you an Utilitech Pro Home Security Expert? Answer questions, earn points and help others
