Question about Kenmore 20022 3.4 cu. ft. Top-Load Washer
Kenmore washer not draining - Kenmore 20022 3.4 cu. ft. Top-Load Washer
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Kenmore washer no spin
Does the washer drain the water quickly?? Are there any error codes?? Usually the drain pump sump is clogged and not draining, thereby not letting the unit advance to spin.
Nov 23, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore he5t washer Changed the pressure switch.
F21 means long drain. Yes, there is something be in the hose. You need to open the filter and clean the pump, too.
Oct 19, 2013 | Kenmore Elite HE5t Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Kenmore Elite Washer
Try this first.
Washer won't drain or spin
Is the drain hose clogged, or the end of the drain hose
more than 96" (2.4
m) above the floor?
Is your voltage low?
Check electrical source or call electrician. Do not use an
extension cord.
Is the "SUD" routine active?
Cycle will complete once extra suds are removed.
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Jul 19, 2008 | Kenmore 22062 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer
Larry, tell Mom to check the lid switch. If it's broken there will be no spin or drain..
Jun 13, 2006 | Kenmore 24872 Top Load Washer
Kenmore 20022 3.4 cu. ft. Top-Load Washer Logo
43 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
