Question about Delta 1246081 Roll Pin
BROKEN HAND FEED ROLL PIN - Delta 1246081 Roll Pin
My feed tray is stuck. It is not in the correct position and there seems to be a little tab stuck on the left hand side. Help, please!
The pin on the left side is used to actuate a safety switch. It must be in the small hole or the machine will not power on. It is spring loaded, so pull it to the right to release the tray.
Aug 27, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
I have an aamco 4000 brake lathe, the disc feed is not working
The cross feed drive shaft is connected to the cross feed spindle via a coupling that resembles a universal joint that is threaded onto the end of the cross feed spindle. Either one of the roll pin holes in the drive shaft coupling has worn and the roll pin fell out or it has broken, or the coupling could have came un-screwed from the cross feed spindle. Remove the 4 bolts that hold the cross feed gearbox on and slowly pull it away from the machine and you should see the coupling I'm describing. My guess is that the roll pin broke or fell out due to wear. You can buy a new drive shaft and coupling or drill and install the next larger roll pin. Either way you should download a parts list for your machine. Just search for it, they can be downloaded free.
Aug 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
Paper do not feed
Hello there,
Have a nice day.
With regards to your concern, here is my suggestion,If you can't even roll it in by hand, there is something stuck on the paper pan. if it just won't feed when you hit the RETURN button, then the paper feed motor (plastic) gear is probably broken, there is a motor with a metal gear available but its hard to get the case off without breaking it, and to have it done costs almost as much as a new machine.
Hope it helps,
Thank you for using fixya
Sep 13, 2011 | Brother GX-6750 Typewriter
Terminal 15 keeps blowing in my 2001 ford f150 supercrew 4x4 lariat i dont know what to do. wont go into gear, lights wont work, windows wont roll down. what should i do???
Central Junction Box / cab fuse panel Fuse 15 ( 5A ) feeds the GEM Module
A leaking windshield ( lower left hand corner ) can cause water to get on the back of the CJB, and corrode the pins to the GEM.
May 30, 2011 | Ford F-150 Cars & Trucks
Hello, there is air coming from the trigger area, I suspect there is some kind of o-ring or some kind of seal broken where the trigger goes into the piston area, I just want to know how to take that apart...
Trigger valve is part number A08368 or (old part #897458). Easy repair. Remove air supply hose, and nails. Remove pin holding trigger to expose trigger valve. Spray soapy water on valve to determin if air is leaking from outer part of valve (orings that contact the body) or around the pin. Remove roll pin/s holding trigger valve in body of gun (use 3mm pin driver, some guns have one pin others 2). With pins removed, apply air pressure to gun and valve will pop out (use heavy glove or rag in hand to catch valve because some valves come out with force). With trigger valve in hand notice the two groves on sides of valve that roll pins contact (when you re-insert valve align valve so groves align with roll pin in body). Remove the two pins holding inner workings of trigger valve. There are two orings on the trigger pin, three orings on the inner valve and two orings on the outer part of body of valve. Usually, the orings that cause leak are the two smallest on trigger pin and three on the inner valve (unless soapy water test indicates outer orings). Orings are available at dewalt service center by part number or if you like to tinker, Lowes has many usefull orings in the plumbing department or replace the whole valve for about $25. Use plenty of silicone paste lube on the orings (sold at lowes). Valve should press in without a great deal of force and be sure to align valve to roll pin in the body. Use 3mm punch to temp. hold valve in gun for test. Good luck
Mar 28, 2011 | Porter Cable Cable No. FR350A Rnd Head...
The paper does not feed no matter the paper release position.
if you can't even roll it in by hand, there is something stuck on the paper pan. if it just won't feed when you hit the RETURN button, then the paper feed motor (plastic) gear is probably broken, there is a motor with a metal gear available but its hard to get the case off without breaking it, and to have it done costs almost as much as a new machine.
Mar 08, 2011 | Brother GX-6750 Typewriter
Manual Paper Feed on HP 5MP fails
Sounds like a feed roll problem.
The is a big feed roll the picks the paper and feeds it in. Clean this feedroll with achohol and rub fairly hard.
I think you can reach the feedroll when you open the unit up.
Dec 17, 2009 | HP LaserJet 5mp Printer
How to feed paper into the Sharp fax UX-108?
first the paper is rolled over the top and then roll it slowly under untill you can pull it out by hand. At this point you can close it and it will automatically start to feed.
Jan 17, 2008 | Sharp UX 108 Roll paper Thermal Fax
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
Open Questions:
How fix Delta/Rockwell 15 drill press from chuck wobbling. I purchased a Delta / Rockwell 15 drill press model 15-091. The chuck wobbles. I ordered some wedges to remove chuck.jacobs #6 wedges After soaking in pb blaster I removed chuck with ease with the wedges. must have Now after looking at what is called the spindle I believe...it is wobbling. I wonder if I am looking at an arbor or the spindle? Above this piece is a threaded section that is about 1/2. I thought of maybe getting a jacobs 34-33c chuck to screw onto this. Seems like if the spindle/arbor is wobbling it still would not run straight or be difficult to properly seat it. I do know that some quills come with a slot to fit a wedge for removing the arbor. Mine does not have this. Without a proper way to remove an arbor it leads me to believe maybe it doesn't have an arbor. Seems that I am looking at the actual spindle. I need this drill press for precision work. If you know about this model.. Please Help !!!!! I am stuck. Do I need to buy a whole spindle? If it is in fact an arbor how are you supposed to remove it? I thought if it is an arbor I could take a grinder and cut 2 slots in the arbor. Then take a really thick washer and cut out a section. to make it a u shape then slide the washer into the grooves I cut out. Then use the wedges on top of that. After tapping the wedges I would think it would come free. Unless it is one solid rod with a taper at the end like an arbor usually has AKA the spindle....HELP!!!! I can't find ANY info on this anywhere. I know someone must have worked on these before.
May 05, 2016 | Delta Drills
Delta 1246081 Roll Pin Logo
22 people viewed this question
Top Delta Drills Experts
Bill Boyd
pete musca
pete musca
Level 1 Expert
Are you a Delta Drill Expert? Answer questions, earn points and help others
