Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Error on computer
When cruzer is withdrawn from computer even though correct procedure is followed ie: Eject and safe to withdraw on XP computer shuts down and says serious errorĀ caused to computer
  • 382 Answers
Re: Error on computer
The drive may be faulty, or stalling to disengage. I would first reformat it if nothing is on it, or nothing that isn't backed up.
Keep me posted.
Posted on Oct 28, 2007
0 characters
3 Points
My Sandisk Cruzer Micro LED won't turn off when Windows 7 displays OK to remove it? Is it OK to remove it anyway?
If you use windows 7 to safely remove the drive and it tells you that it's fine to do so then you're ok.
The reason you do this is because if there's any files still being used by Windows when you pull the drive, you could damage those files or even the file system. When you safely remove the device you're telling Windows to stop any and all connections with the device. Even if the light is still on, if Windows is telling you it's ok, then it means that it's no longer being used by any programs or the OS
Mar 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I want to eject Have Cruzer Titanium 2.0 USB memory plugged into computer. No programs or files from it are currently in use. After clicking on Safely Remove hardware, the message Problem Ejecting USB Mass...
Make sure you have all programs and folders closed. Then try stopping usb mass storage, there should be more then one option so try removing the drive itself on the list. If that doesn't work. I myself would probably just restart the computer. Then try again.
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cannot save to sandisk cruzer 2gb flash drive
This seems to occur when used on different computers (especially if using sync software) and seems to occur if a drive is removed when Word (or whatever) is still open. I saved the files with an a at the end to resolve it. Always use the safe disconnect option in the taskbar
Mar 12, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 2.0GB not allowing me to erase files
your drive has become write protected for this file and folders.
run computer in safe mode , chances of recovery good in safe mode.
anaesarora online
Jan 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer Micro lights up but won't read
I would say it's DOA. These thing don't seem to have a very long life span, even though I have the exact same one but I'm expecting it to go out at any time. I had a 128mb that bit the dust the same as yours. But try those free data recovery software on the net you may get lucky???
Nov 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer micro 4GB can't be accessed;7310930;/fileinfo.html
This software will low level format your drive back to factory settings.Just like when you first got it. If your machine racognizes the drive but you get an I/O error this is the fix. GOOD LUCK !
May 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to recover data from a seemingly dead/non-functional USB flash drive
I own three flash drives, and follow this procedure. When you connect a flash drive, it should show up in "My Computer" as a removable drive - with a letter designation. Windows 98 requires driver software, XP and VISTA does NOT.
When you DISCONNECT the flash drive, you should "right click" on the drive icon, and select EJECT. The little light on the flash drive will go OUT, and THEN IT IS SAFE TO REMOVE IT. If you just pull the flash drive out without going through the disconnect ritual, you risk blowing the drive, and it is kaput. Doesn't always happen, but it can.
May 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer 4Gb not found on XP
I have the same issue. I have found a temporary solution though. I have a Sandisk 4GB Cruzer and an HP Laserjet 1022N connected VIA USB. When I uninstall the USB Printing support driver from Device Manager then plug in the Cruzer it recognizes it right away. Not quite sure why this would happen though
Apr 02, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
83 people viewed this question
Top SanDisk Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a SanDisk Hard Drive Expert? Answer questions, earn points and help others
