Question about Kenmore Washing Machines
Error E56 on kenmore washer - Kenmore Washing Machines
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: affinity front loading washer error e56, what does this mean?
1) Read the owner manual and proceed section troubleshooting,this mean the motor, probably is defective and need replace.
2) Try to run the software diagnostic.and make the test 9 for solution or diagnostic.
3) or call some tech from company or another you know it
God bless you
Posted on Sep 26, 2012
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: washer would not drain or spin (frigidaire aft6000sf1) error code E56
    Hello - Typically, error code E56 commonly refers to a motor issue. It indicates that either the motor has overheated and/or will not drain/spin. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately 30 minutes for the washer to cool down and turn the unit back on. If error code persists, I personally suggest contacting a professional to accurately diagnose the issue at hand.
    Posted on Apr 05, 2013
    What does error code E56 what does error code E56 mean
    Unfortunately, and error code of E56 indicates a high motor current. There are a couple of issues that could cause this problem and if you're comfortable working on it yourself, I can try to direct you to self-help website that will explain how to diagnose the issue. Be advised it will require some machine disassembly to test whether it's actually a motor problem or if there is an issue with the tub assembly being difficult to turn.
    Mar 06, 2015 | Frigidaire Washing Machines
    Tip
    Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
    Hi.
    This error codes apply to Frigidaire Affinity washers and dryers:
    E11 - Fill time too long.
    E13 - Water leak in tub, or air leak in air bell.
    E14 - Reed switch.
    E21 - Water not pumping out fast enough.
    E23 - Drain pump relay on control board failed.
    E24 - Drain pump relay on control board failed.
    E31 - Pressure sensor not communicating with control board.
    E35 - Pressure sensor indicates water overfill.
    E41 - Control board indicates door switch is open.
    E42 - Door remains locked after cycle is completed.
    E43 - Control board problem
    E44 - Control board problem.
    E45 - Control board problem.
    E46 - Control board problem.
    E47 - Control board is sensing the door PTC circuit is open during spin.
    E48 - Control board is sensing the door PTC circuit is closed.
    E4A - Program Timeout Fault.
    E52 - Bad signal from tacho generator.
    E55 - Motor overheating.
    E56 - High motor current.
    E57 - High current on inverter.
    E58 - High current on motor phase.
    E59 - No tacho signal for 3 seconds.
    E5A - High temperature on heat sink.
    E5B - High temperature on heat sink.
    E5C - High temperature on heat sink.
    E5D - Communication problem.
    E5E - Communication problem.
    E5F - Communication problem.
    E67 - Input voltage on microprocessor incorrect.
    E75 - Water temperature sensor circuit (digital readout models only).
    E76 - NTC temperature for the cold water valve over the limits
    E95 - Communication error.
    E9E -Voltage error.
    EB1 - Incoming power frequency out of limits.
    EB2 - incoming line voltage above 130 VAC.
    EB3 - Incoming line voltage below 90 VAC.
    EF1 - Clogged drain pump.
    EF2 - Too much soap.
    on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
    What is error code E56
    Motor over heating, take the belt off and see if tub spins free. If it does, bad motor. If not check tub bearings.
    How can I tell whether to replace motor, motor controller or main control board on my frigidaire affinity washer ( ATF7000FS1 ) after error code E56? Test 9 gives motor winding resistance of 7.2, 7.2 and...
    Hello friend, thank you for your inquiry!
    Based off the information from your manufacturer "E56" stands for high motor current. Looking up information for your technical data sheet it states that you need to perform test 9:
    1. Remove the belt from the motor and spin the motor pulley.
    Does the motor spin free? No, replace the motor. Yes, go to step (3).
    2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3).
    3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
    Based off that information you would need to replace your motor. If you feel unsure about repairs I would recommend reaching out to a professional for proper diagnosis and repair. I hope this helps. -Matt
    Sep 15, 2014 | Frigidaire ATF7000 3.5 cu.ft. Affinity...
    What does e56 error code mean
    Good afternoon friend, thank you for allowing me to assist you!
    Typically on a Frigidaire washer an "E56" error code stands for a high motor current. Which means you could be seeing an issue with your motor or speed control board. If you are getting that error code you could be seeing a miscommunication within the appliance, I would suggest a reset to your washer would clear any false error codes. You can reset the appliance by unplugging the power cord or flipping the household circuit breaker for ten minutes. I hope this is helpful. -Matt
    Jul 30, 2014 | Frigidaire Washing Machines
    E56
    Hi Susan, this is JK. I understand that you are receiving an error E56 on your washer. This error E56 is indicating a high motor current, the motor has overheated. The washer motor will stop when it is overheated, allow the motor to cool down and attempt to wash again. If the problem persists, you would need to contact a service provider to test the motor, motor pulley, tub pulley and the bearings. Hope this helps!
    Mar 24, 2014 | Frigidaire Affinity ATF8000FE
    Washer would not drain or spin (frigidaire aft6000sf1) error code E56
    Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire front load washer code E56
    Hello - Typically error code E56 indicates that the motor is overheated and unit will not shut off. Allow 30 minutes for the washer motor to cool down and try again. If it proves to be ineffective contact a professional to move forward accurately.
    Nov 23, 2012 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
    Affinity front loading washer error e56, what does this mean?
    God bless you
    Sep 26, 2012 | Frigidaire Washing Machines
    E56 on electrolux EWF14108W
    e56 is a motor or motor control circuit board fault
    May 29, 2010 | Electrolux EW1000i Front Load Washer
    Washing Machines Logo
    24 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
