Question about Kenmore 98702 Stacked Washer/Dryer
Model #110.88752793 runs but does not heat
The dryer starts and runs but does not heat up.
Dryer will not stop running
If the start switch is stuck or the start knob is stuck in the start position the dryer will run when the door is closed, and the timer is at at a time setting. if you have no heat you might need a heating element or your unit might have a thermal fuse that would need replacing.
Jan 18, 2014 | Frigidaire FEQ1442ES Electric Dryer
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
My Kenmore 500 series electric dryer seems to be heating, but just stopped running. I hit the start button, and the drum heated up, but did not start turning. I'm guessing that the start switch is not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 14, 2010 | Kenmore Elite HE4 Electric Dryer
Gas dryer initially heats then heating stops
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
The dryer runs but does not have any heat. I
Start by hooking each of the thermostat wires together to bypass . When dryer starts heating, you have located the defective one.
Nov 08, 2009 | Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
