Question about HP LaserJet 1320 Printer
Spots on paper
When printing I get several ink spots on paper of left side have clean outside rollers still ink spots
IB4G2008
  • 3587 Answers
SOURCE: Printer crunching paper
either it's a paper stuck under roller, or along that side of the raceway, or the roller on that side is dirty, and can't grab the paper well.
Posted on Feb 25, 2008
SOURCE: printer leaves black spots on paper
The black spots mean you either need a new imaging drum, transfer kit or fuser. You'll have to print some stuff and try to catch where the black marks are appearing. Try this method (it's called a Half-self test)
Load 2 -3 sheets of letter paper in tray one (manual feed) and remove paper from the rest of the trays.
From the information menu, request a demo page
The MOMENT the tail end of the paper disappears into the printer, open the right door. Open the front doors and release the levers for the imaging drum and the transfer drum. Carefully remove both pieces and examine your paper.
You should find the paper partway on the transfer belt but not in the fuser. If you see black marks here, start with the imaging drum. Open the shutter that covers the sea green shiny roller and look for marks on the drum (you'll see build up on the edges, that's normal, you should not see any scratches, pockmarks or toner on the center of the drum). If it looks clear, take a look at the transfer drum for marks or cuts on it's surface. (note: the transfer drum can be cleaned off with a dry lint free cloth, do not touch the shiny sea green roller of the image drum)
If everything looks good there, then likely the black marks are coming from the fuser. Let the printer sit, turned off for about half an hour to allow the fuser to cool. You can then remove the fuser and look at the rollers to see if there is any build up or damage there.
If you are not seeing any obvious issues with any of these parts, then start with the imaging drum. If you know that any of these parts have never been changed, then change them as they do have a limit to how many pages and how much time they can be used for.
Posted on Feb 17, 2009
  • 52 Answers
SOURCE: ink spots on paper
If the spots are all one color, the toner cartridge of that color has a problem. Check the drum on that cartridge and make sure there are no bad spots on it. Your cartridge could be leaking toner.
Posted on Feb 27, 2009
  • 21 Answers
SOURCE: black line on left side of paper
It sounds like a cartridge issue. Try changing the cartridge.
Posted on May 26, 2009
  • 40 Answers
SOURCE: The printer is transferring ink from the top left
Image problems on laser printers are almost always caused by the toner cartridge or the fuser. If you have already tried a new toner cartridge and that has not fixed the problem you need a new fuser. A fuser that is going bad will cause lines, smudges and ghost images. You can buy it alone or as part of the maintenance kit. www.printerworks.com is a good place for HP parts. Search by model number to see what you need.
Posted on Oct 05, 2009
It keeps getting ink on the rollers(black) and transferring this to the paper in lines from the rollers. I have tried scanning a blank piece of paper but still keeps printing lines from the roller
You ink absorber is full then you need to clean it,maybe you cannot see by looking outside but if you disassemble it you can see inside 2 or 3 absorber tank. You can wash it or replace it a new absorber ...
try to put a waste tank outside your printer, you can see the small hose inside that connected to the print head when it park, just add another hose and a plastic bottle to place outside you printer this will be your waste tank now, so when you head cleaning your printer a lot of ink are uses that goin to your waste tank, by doing that it's easy to dispose you waste ink
Sep 13, 2015 | Epson Stylus Multifunction Inkjet Printer/...
How do I fix HP LaserJet P1606dn printing issue? it continues to print vertical line/ smudge on the far left of the printed document. Does anyone have any suggestion regarding this issue?
The smudges on the side of the paper is most likely a piece of something rubbing against the paper just after the printer puts the ink on the paper. Inspect as much as possible the path that paper takes. Look at rollers. Anything that grab the paper. Look for ink and dust build up. As for the vertical lines. Could be several things. I you haven't used you printer for awhile the ink in the nozzle could of dried up. Most new printers have a nozzle cleaning function. Try that it a couple of times. See if that helps. If it shows any sign of change after that, it dried up ink. It's a hassle to try to get the ink flowing again. I normally just to replace the cartridges. Let me know if this helps or not.
Aug 05, 2015 | HP LaserJet Pro P1606DN Laser Printer with...
Ink spots on back of printed page from Canon i860. What to do?
Type in your search engine How to get rid of ink spots on back of printed page from Canon i860 printer.
It will take you to How to download a manual that will help you fix this issue. PDF.
Jun 18, 2017 | Canon i860 InkJet Photo Printer
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
My HP Color LaserJet 2600n is printing with small black dots on the left side of the paper. The toner and ink was recently replaced. Is there a plausible reason for this? Thank you!
Could be toner build-up on the fuser sleeve. Pull out the fuser and check the rollers for spots.
Try running cleaning pages before replacing fuser.
Jul 28, 2011 | HP Color LaserJet 2600n Printer
Thank you Kitty but I'm not clear on how cleaning the Print Heads and replacing toner would fix this faded banding issue. I printed long Vertical bars of Magenta, Cyan, Yellow and Black. All colors fad at...
you need to clear the rollers and the heat drum (fixes the image and melts the toner onto the paper) if you have done any two sided copy, or have used paper with an image on one side, the ink may have gotten onto the roller and left a trace which would account for the banding being in the same place all the time. the rollers and etc are difficult to get at, and not really a job for amateurs
Mar 10, 2011 | Samsung Office Equipment & Supplies
Cleared paper jam caused by heat spot on roller and dried ink sticking to that spot. Cleaned off dried ink and reassembled. Now on restart normal sequence shows ready to print, but on "test...
I think it is possible that the reassembly after the cleaning of the rollers had detached or shifted the sensor or settings/alignment of the intake mechanism.
Hence i would suggest that you can remove the assembly and carefully check once again if there was any wrong settings/aligment while you set it back .
The in-detect switch and the roller spacing must be correct.
Also you can remove printer, un-install drivers, then reinstall and connect printer to be detected and installed.
Hope this clears the fault.
Seasons greetings.
Dec 24, 2010 | HP LaserJet 1100 Printer
Having an issue with my ML 1210. It prints these
The roller had an ink spot it it which is transferring to the paper. clean the roller carefully with some rubbing alcohol on a clean cloth. then let it air dry for 30 minutes before using it. Have the printer unplugged while you do this and use a minimal amount of alcohol, just a damp cloth will do the job.
Oct 02, 2009 | Samsung ML 1210 Laser Printer
Ink marks on paper
seems that the Print roller needs a cleaning. get it cleaned as there might be some extra ink on the roller.
Hope this Help.
Cheers!!!
Jul 16, 2009 | Lexmark E330 Laser Printer
Splotching and spotting ink
The roller cleaning will require you to remove cover to clean the full roller with alcohol to remove ink build up. Have you tried to just run/feed a blank piece of paper through to see if you have roller ink roll off?
This also sounds like a bad cartridge with clogged jets...
Jun 15, 2009 | Canon i80 InkJet Printer
HP LaserJet 1320 Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
