Question about Cell Phones
Master code of cell phone chinese BQ K66
I forgot pin code.as disscuss i enter imei number.now i wanna master code to open this cell. Pls help.
edwin270
  • 308 Answers
SOURCE: Resetting Security Code
357593006548708.........for this phone try resetting the phone or formatting by entring *#7870# for resetting and *#7370# for formatting in any of the case you should have your original number which is 12345 as the new code after resetting of formating but for formtting you would lose every contacts so you are advice to keep a copy of every important dorcument.
for nokia 5300 also try resetting or formatting to restore the usual pin code "12345" and to do this first copy all contacts and information need first even is restting it(which you do not lose any information) ........... to reset enter *#7870# and to formate enter *#7370# please try the first method before proceeding to the second one.
for nokia 3110c please this is your master code   6003104322
Posted on May 19, 2008
try *#0204376647# and also try inserting 0204376647 this code in the place of security code ... (for imei 357593006548708)
it should work ..
(for imei 358378004521736) this is the code 1125306552 ....
(for imei 355397009002339) this is the code 3537356212 ...
Posted on Sep 09, 2008
ur unlock code is 3537356212.
email me at suhailraza_786@hotmail.com.
your sincerely mohammed sohel
Posted on Apr 15, 2009
njvinod
  • 1462 Answers
SOURCE: i forgot my nokia 3500c security code and entered wrong ones
HI,
You have to type in security code of your phone in order to log into the phone....
By default the security code is 12345 and if you have changed it, you must be knowing....
BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
also try: http://nfader.z-host.ru/
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Aug 15, 2009
SOURCE: have forgot security code for
If you've forgot Security code of your Nokia mobile phone,
use Security Mastercode instead.Check this code out 0112360151.
I hope this helps.
Good luck.
Posted on Mar 05, 2011
IS pin blocked .enter pin code
- To unlock you Nokia 2690 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone.
- With the help of this IMEI code we can get the master code of your mobile and unlock the
mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by typing
*#06# into the phone keypad.
Hope this helps , please rate and leave a comment if the solution was helpful, thanks!
Aug 23, 2011 | Nokia 2690 Cell Phone
I forgot my security code in nokia 2700 classic.pls give a master code
To reset the Phone from the security lock get the master reset code from service provider...
Jul 25, 2011 | Nokia Classic 2700 Cell Phone
I forgot my nokia 2700 c2 security code my phone IMEI no 354350/04/597801/3 pls help me i have my very useful contact on it and i m facing problem pls.
The master code is a 10 digit number that will always be accepted as if it were your actual security code. You can use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Find Nokia Master Security Code. Simply enter your 15 digit serial / IMEI number. Your master code will then be calculated instantly. Cick here to find your master security code.
Jul 19, 2011 | Nokia Classic 2700 Cell Phone
Hi the keypad get locked in my mobile (2690). I have changed the security code & tried more than thrice by forgotting it. Pls help me.
If you've forgot Security code of your Nokia mobile phone, you can use Security Master-code instead.
Just follow the following steps.
  • Dial *#06# on your dial-screen for IMEI number
  • Open this site http://nfader.su/
  • Type that IMEI number in the box and check " I'm the legal owner "
  • Press Generate
You'll see the master-code for your phone.
That master-code will help you to set a new security code.
Try this.
Good-luck :)
Apr 28, 2011 | Nokia 2690 Cell Phone
I wanna rest my security code for my nokia 5310
Dec 04, 2009 | Nokia 5310 Cellular Phone
Forgot nokia n70 pin code
Get your phone IMEI number which is a fifteen digits number located in the battery compartment of your phone.
Then Visit http://www.nokiamastercode.com
Input the imei number at the site to generate a master reset code which you input when you switch on your phone.
This enables you to reset your phone security code.
Rate this fixya. Good luck.
Aug 02, 2009 | Nokia N70 Cellular Phone
Security code Nokia 3110 classic
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 17, 2008 | Nokia 3110 Cellular Phone
SIM pin code:
Master Reset Code
Apr 13, 2008 | Nokia 3110 Cellular Phone
How to break security code
Master Reset Code
For mathyn IMEI 010972008260174 Mastercode 5255056051
For mc hot IMEI 359838011209921 Mastercode 1600246040
For Guest IMEI Type *#06# to get it. Mastercode ??????????
For emanuelgaby IMEI 354528013559796 Mastercode 7367245612
This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (any) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
Mar 20, 2008 | Nokia 1600 Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
