Question about Jet AFS-1000B Air Purifier
Snaps breaker when turned on - Jet AFS-1000B Air Purifier
Why won't my Hoover Platinum turn on?
Check and see if there is a reset button for the vacuum head this trips sometime to protect the head motor. Also if the roller heads bind they can snap the belt if it is belt driven. If it is direct drive then I would look for the trip or reset button.
May 14, 2014 | Hoover Platinum Lightweight Upright Vacuum...
My honeywell electronic air cleaner snaps all the time
Just had the "snapping" problem over the last 5 weeks. First try was to wash the cells in the normal fashion. when the snapping started again in a week I washed the cells in the dishwasher. They began snapping again in a week or less so I removed the cells and made a very close inspection of them. Using a very bright light I noticed the wires had a very uniform coating of something light gray in color. I picked at that coating with my finger nails and it came off to reveal the BARE wire underneath, Ah Ha, that coating was NOT supposed to be there ALL the time. So, CAREFULLY using my fingernails and a bit of wooden stick I scratched off that coating on all of the wires (it goes all round the wire) to reveal the bare wire and now it works with out snapping. Those wires can be broken if you are not careful. They can be replaced but that's just more hassle than being careful.
Good Luck, be careful, it can be done by the homeowner (and should be done too).
Dec 29, 2011 | Honeywell (F50F1032) Air Purifier
I "won" a Rainmate from
No, not that I'm aware of. But, the problem itself, may be in the electrical receptacle. A loose wire, a bad connection or interior damage could all cause the circuit breaker to trip. Or it may simply be the case, of line that air purifier is plugged into, is simply overloaded, because of other electrical appliances are on the same circuit of tripped the circuit breaker. Most air purifiers have their on circuit breaker or fuse built-in to the unit. And that, will usually trip before the circuit breaker in the breaker panel of your home.
Here's how you test that theory: Plug the unit into another outlet, that is on an entirely different circuit than the original one and turn it ON. If this trips a different circuit breaker, then you know it's an internal problem with the unit. If it doesn't trip the circuit breaker, the problem is with the original receptacle or the line that feeds that receptacle and it's circuit breaker.
Hope this helped you to troubleshoot and solve the problem.
Jun 13, 2011 | Rainbow Rainmate Air Purifier
My Ionic Breeze Model S1637 just stopped working and I don't know what to do. Is there a solution for this. It appears as if the unit is not getting any power?
Test the outlet that it's plugged into, to make sure it's still functioning properly. There may be a loose connection at the receptacle or the circuit breaker in your home's circuit breaker panel, for that receptacle may have been tripped. If it is, before resetting it, make sure the air purifier is not plugged in to it. Then plug the unit in and turn it ON. If the circuit breaker trips again, there's a wiring short in the air purifier. Contact Sharper Image for possible repair or replacement.
Apr 04, 2011 | Sharper Image Ionic Breeze 3.0 Air...
Dear Expert, I do hear scary sound like a electric spark once in a while, and then stop. Should I turn off the switch? Thank you.
Arcing (snapping) seems too frequent
1. If the electronic cell(s) are wet from washing, turn the air cleaner off for two to
three hours.
2. Check the cell(s) for broken ionizer wires or bent plates. Repair if necessary.
3. Wash cell(s) and prefilter(s) if dirty.
Sep 28, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Eletrical snapping sound
This is normal....when dust passes through this filter it is "Zapped" that's how the electronic air filter works
Oct 25, 2009 | Honeywell HFD-130 Air Purifier
Ozone function causing blue spark and snapping
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 13, 2009 | Air Purifiers
Jet AFS-1000B Air Purifier Logo
47 people viewed this question
Top Jet Air Purifiers Experts
Are you a Jet Air Purifier Expert? Answer questions, earn points and help others
