Question about Kirby Ultimate G Bagged Upright Vacuum
How do I replace the belt?
It kinda shows on the vacumn itself but I can't understand it. Please help!!
  • 1 more comment
  • linlou Nov 10, 2007
    i took the cleaner apart to connect the shampooer when i put it back together the carpet brush would not turn
  • grannelin Nov 20, 2007
    how do you put the belt on??? I cannot figure it out
  • Anonymous Dec 05, 2007
    how do i hook the belt to the thing a ma jig? Not sure what the name is.
  • 357 Answers
Posted on Nov 09, 2007
  • Marci Marple
    Marci Marple Dec 05, 2007
    INAPPROPRIATE??? Can't please everyone, I
Can u put a video on how to put a belt on a Kirby vacumn
Try this YouTube video:
Mar 01, 2015 | Kirby Vacuums
When I use vacumn there is a smell of rubber almost straight away
Replace the belt. Belts must be stretched to almost twice their original length and will lose elasticity. Replace the belt at least every 6 months.
Feb 14, 2015 | Vacuums
My vacumn won't pick or suction up and bag is not full. I cleaned out the hose checked and belt running I have no other answer please help. It's an upright lux guardian
The output filter on that unit is HEPA and traps all particles. You need to clean or replace that filter because the airflow cannot leave through it and it wont develop suction.
Feb 06, 2015 | Vacuums
Rotary brush does not spin when using on carpet
The brushes are usually belt-driven. You may need to replace the belt.
Dec 16, 2017 | Dyson DC29 Animal Vacuum
I thought I was buying a manual. I put a new belt on my vacumn but it makes a funny noise and does not leave vacumn lines on the carpet like it used. I don't know if it takes two belts or one.Wish I...
Hi Frrank: The Owner's Manual for the Euro-Pro Infinity NV31N Vacuum can be downloaded in PDF from the following site:
See pages 15 and 16 of the PDF for instruction on replacing the single belt.
If this is not the manual for your model, please reply and will try again.
Thank you for using FixYa!
Feb 17, 2012 | Euro-Pro NV31 Infinity Vacuum
Bissell 8920 proheat x2 brushes not turning i only noticed this after i finished cleaning.. or kinda cleaning because of the brushes ntot turning.. water comes out fine suction is fine but its not...
Here's a link to a very helpful video that shows you step by step on how to access and replace the belt on your machine. When the brushes stop spinning, but the rest of the machine works fine, this is a tell-tale sign that your belt has gone bad.
Video Showing how to access and change belt:
If you open up your machine and find that the belt is still engaged, or you replace it and this doesn't fix your problem, please feel free to use the comment form here on this repair page and I'll be happy to walk you through some more advanced diagnosing.
If you found this helpful, please be so kind and rate my repair helpful, or leave some feedback. This is really appreciated.
Chris Jones
Apr 21, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Odd noise coming from central vacumn cleaner
The rattling noise, will likely increase when the head is flipped upside down. Generally means you have a stone caught in the belt or a blown or stripped tooth on the belt.
If you gently squeeze the outside edges of the light housing it will pop off to reveal two screws to remove the lid. Check for other screws at the neck of the power head. Once removed your belt and brush will be visible. Remove the brush roll with end caps and flip the belt inside out rolling it between your finger , look for cracks or a floppy or missing tooth. Replace if any sign of wear.
Inspect the dust caps on your brush. There is a washer under each, likely buried in lint. Do not lose as these are a spacers for each end of the brush. Clean shaft and lube with WD40. Spray caps with the same. vacuum loose grit and dust bunnies away from motor and reinstall, your red button must align with the lid when replacing
Jul 19, 2009 | Hayden Industries SuperVac 2400 Central...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
My vacumn wont pick up from the bottom but the hose works fine. I emptied the bag and the green light is on.
Either the glide plate at the bottom is blocked or the belt is broken
Please leave feedback
Feb 12, 2009 | Bissell 3522 PowerForce Bagged Upright...
How do I get inside to replace u belt ?
Remove the three philips screws holding the yellow cover on the base. It will lift off, exposing the roller bar and belt. There are further instructions for belt change on a label inside.
Sep 04, 2008 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
37 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
