Question about Dual XD-5110 CD Player
The tuner spins but doesnt change station. dual xd5110. help
What could be the problem with my tv cause it searches continously without finding any station.it thereafter remains on channel 0 with no image or sound.i have changed tuners but that doesnt help.plea
There seems to be an incompatibility between the TV's setting and the antenna's input.
The TV doesn't see the antenna connection and keeps searching.
Somehow you have to get the TV's 'cable' setting in the menu to 'over the air'.
Is there a clean signal coming to the TV? Sometimes a cable can be compromised where the signal never reaches the input connection. Check both ends or at least replace the cable temporarily.
Last but not least, the TV maybe set to a PIP (secondary tuner with a picture in a picture) and the tuner is not electronically connected.
Jan 05, 2015 | Televison & Video
My tv doesnt get any stations already scaned it its dtv ready it is a sony
Check the tuner. Check all supply voltages to it. It is a skilled job. If all voltages are OK, replace the tuner.
Apr 17, 2012 | Sony FD Trinitron WEGA KV-32HS420 32" TV
How to change tuner to pick up all frequence's eg: goes from 95.5 to 95.7 how do i get it to change to 95.6 thanks jason
It will only tune into odd numbered stations because US radio station only broadcast in odd number stations (ex 95.5,95.7,96.3). You can change the area. Area 1 is North America, Area 2 is other areas. Press "Menu"->"Setup"->"Tuner"->"Tuner Area", then select 1 or 2. After setting, press and hold "Menu" for at least 2 seconds. This may give you the frequency you are looking for.
Apr 14, 2011 | Alpine CDA-9855 CD Player
Gharge kit not gharging battery
if its not a problem with the charge station then it must be the battery. i had the same problem. i had a microsoft(xbox 360) charge station and bought a "gigaware" battery and charger for my controller. the cord charged the gigaware just fine but the dual charge station would not. good luck with it bud sorry if this doesnt help. key point is that the battery has to be the same brand as the charge station.
Nov 11, 2010 | Video Game Consoles & Games
I need a wiring diagram so i can install my dual XD5110 am/fm cd reciever. my interior and dash wont turn on anymore. please help!
The problem is that Voyager 1997 MEX becomes stop and can`t start again until 20 mins later, I don`t have any wiring diagram.
Thanks for your response.
Oct 17, 2010 | 1997 Plymouth Voyager
My plasma does not split screan to show two channels (input) from the video recorder.
Correct. It doesnt. What are you trying to accomplish? If it is PIP from a cable box this needs to be within a dual tuner cable box. This has nothing to do with your TV.
Any TV that can do PIP has dual tuners.
Dec 01, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Radio tuner stopped working
replace Bad Circuit Dsp Pcb the rca part number is #265973
Jan 13, 2009 | RCA RTD258 System
SI686
To activate the sound soother press the round button on the bottom left of the unit marked soother. To change the Soother stations press the "Tuner buttons either left or right. The tuner buttons are located on the bottom half of the unit above the volume buttons. one click of the tuner button moves one station on the sound soother selection.
Jul 06, 2008 | Sharper Image SI686 Clock Radio
Pip for my iQB36B44w
The PIP may only work with an external tuner or source (VCR, DVD, CATV box, etc) If your TV doesnt say "dual tuner" then you need an external source for the PIP (Use a VCR and its tuner for instance)
Feb 13, 2008 | Zenith B27A11Z 27" TV
Changing Channels
Unfortunately, no. The tuner in your DVD recorder works differently than how your satellite receiver works. You *must* use the satellite receiver to select the active channel, and then send that channel to one of the inputs on your recorder. You can then record that channel. Unless your satellite receiver is has "dual tuners" in it, you are stuck watching the same channel that the DVD recorder is recording. If your goal is primarily time-shifting of shows (as opposed to archiving shows forever to DVD), you might consider getting a different satellite receiver with a built-in DVR (hard disk recorder). These allow you to mark shows in advance, have them recorded to the hard drive, and then you can watch them whenever you want, skipping all the commercials. You also get the ability to pause and rewind live TV.
Apr 14, 2007 | Panasonic DMR-E50 DVD Recorder
Dual XD-5110 CD Player Logo
14 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
