Question about Nuheat SOLO Thermostat
Nuheat soloi thermostat
My thermostst for heated floor is blank and doesnt do nothing my model is solo
Looking for how to hook up a thermostst
That all depends on how old the system is, wires colors change over the years,.
May 19, 2017 | Dayton Heating & Cooling
Nuheat thermostat keeps rebooting
replace the thermistat module..sounds like it has a bug in the firmware
Jan 08, 2014 | Nuheat Harmony Thermostat
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
The screen of Nuheat Solo keeps flashing, the floor is cold. It seems like that the whole system stop operating. Yesterday, it was fine.
I had the same problem. It is caused by a failure in the thermostat, usually brought on by a power surge. Unfortunately, this product is poorly designed, and cannot handle common power surges in homes. The only solution is to replace the thermostat unit. Nuheat has a decent warranty (3 years) so you may qualify for a free replacement.
Dec 22, 2013 | Nuheat SOLO Thermostat
I have a carrier heat pump model # 38RQ034300 I need instructions for. To maintenance and use thermostst correctly
That is model number for your outdoor unit. Thermostats are not dedicated to any particular model outdoor unit. You need instructions for the thermostat so the thermostat make and model number are needed.
Oct 16, 2010 | Carrier Heating & Cooling
We have a split level home. The heating system is steam/boiler heat. There are three thermostats that control the heat on the different levels. The thermostats on the top floors are set at 68 sometimes...
JUST A REFERENCE; Unit designed to heat 900 sqft. 300 sqft per thermostat. When heat comes on and only 1 zone is calling the unit doesn't heat 1/3. It heats the 900sqft it's designed to. Therefore that "extra heat" HAS TO go somewhere. If it doesnt go to the "non calling" zones the unit would shut down on safety because it would get too hot. So, open a window or you need a bypass damper with bypass duct installed that when the heat comes on for only one zone that "bypass" opens and sends the "extra heat" back into the return rather than to the "non calling" zones. To answer your question, nothing is wrong with your unit or tstats, it's the duct work. Maybe $600 to $800
Jun 05, 2017 | Heating & Cooling
Newly installed Goodman GPG13 gas/electric package unit installed. Cannot get AC to cycle on. Unit produces heat at all thermostst settings.
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Sep 21, 2008 | Goodman Heating & Cooling
Nuheat SOLO Thermostat Logo
62 people viewed this question
Top Nuheat Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Nuheat Heating and Cooling Expert? Answer questions, earn points and help others
