Question about Vacuums
Won't stay on bare floor settings. Keeps clicking back to carpet
SOURCE: works on carpet not on bare floors
It's not supposed to rotate on bare floors
Posted on Dec 25, 2008
  • 1214 Answers
SOURCE: Kenmore Vacuum 116.36623501 does not stay on bare floor setting
It sounds like there is something wrong with the latching assembly. GO to the Sears Parts website and enter your Model number. Look at the parts assembly for the Nozzle, and the problem will be in one of items 12 through 17.
Posted on Jan 15, 2009
  • 143 Answers
SOURCE: the adjustment knob for bare floor will not stay in position
broken catch. recommend dyson service as it is not user replaceable.
Posted on Sep 14, 2009
BElectric
  • 1140 Answers
SOURCE: when i set the floor setting to carpet, it makes a
There is one major difference between the hard floor setting and the carpet setting - the brushbar doesn't spin on the hard floor setting. Hopefully this is a simple problem - the rattling noise suggests there may be something trapped behind the brush rollers. You can inspect this by removing the sole plate from the vacuum. Doing this may allow any trapped objects to fall out without need for any further inspection:
To remove the sole plate:
1. Lie the dyson on it's side so you can access the underside or sit on a chair, turn the vacuum upside down and hold it between your knees.
2. Using a coin or a large flat-bladed screwdriver undo the two yellow fasteners on either side of the "sole plate" which covers the brush rollers.
3. Pivot the back edge of the sole plate upwards and remove it
Any loose debris can now be easily removed, While the sole plate is removed, it is a good opportunity to inspect the brushes and remove anything else that may be stuck to it.
Replacing the sole plate is the exact reverse of the removal process. Before replacing the sole plate, ensure that the brush bar is correctly and fully inserted.
There are other possible reason for the rattling noise, but your description leads me to believe that this should cure the fault. Inspect the brushbar first and then post back if you need further assistance.
Regards,
BElectric
Posted on Dec 15, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: when i set it on carpet instead of bare floor it
    Sorry to hear you're having difficulties using your DC14 on this particular carpet. You may want to contact your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brush. Manufacturers sometimes recommend cleaning certain types of carpeting using suction only.
    If you have any further queries about using or maintaining your Dyson vacuum cleaner, please get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Aug 15, 2011
    Brush roller works on carpet setting but not on floor setting. have already cleaned roller. suction is great. just won't do anything on floor setting (all 3 settings)
    Check the arms that make the roller go up and down to achieve the settings. There may be something clogged in there.GOOD LUCK FRIEND
    Sep 14, 2014 | Electrolux EL8807A Precision BrushRoll...
    Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
    I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
    Feb 21, 2014 | Eureka Vacuums
    The bare floor/carpet switch moves on it's own from bare floor to carpet all the time.
    I'm sorry to hear you're having difficulties with your DC07. When you have your brush control set to 'Carpets', the brushbar should run when the cleaner is reclined into the vacuuming position, and shut off when you stand the cleaner upright. When you have the brush control set to 'Hard floors', it should remain in the off position until you change it manually back to 'Carpets'.
    If it won't stay in the 'Hard floors' position during use, it's probably best if you get in touch with us directly so we can determine if there's a fault, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Oct 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Just got my dc33... one issue... the dial switch to control btn bare floor / carpet mode doesn't seem holding in it's position when I set to the bare floor mode... it keeps coming back to carpet...
    I'm sorry to hear you're having difficulties with your DC33. If you're concerned that the brush control doesn't seem to be staying in position, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your machine, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Aug 24, 2011 | Dyson DC33 Bagged Upright Vacuum
    Brush will not spin
    Hello :
    Try this: switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
    PLEASE RATE !
    Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Reset button or Fuse on my Infinity?
    Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
    Jan 09, 2010 | Vacuums
    The adjustment knob for bare floor will not stay in position
    Jul 24, 2009 | Dyson DC14 All floors Bagless Upright...
    Dyson vacuum brush roll doesn't turn
    The brushbar should only turn when you meet two conditions:
    1) When you step on the front of the machine and pull back on the handle (recline the machine in other words)
    2) The dial is set to CARPETS
    The brushbar shouldn't turn at all when it is set to the BEAR FLOORS setting.
    To rectify the problem - call the Dyson Helpline so that they can refer you to an authorized dealer in your area - the repair dealer will inspect the dial and figure out why the functionality seems to be switched. They'll be able to fix it for you.
    Mar 19, 2009 | Dyson DC07 All Floors Bagless Upright...
    Dec 27, 2008 | Kenmore 25512/ 25513 Progressive Canister...
    Works on carpet not on bare floors
    Nov 14, 2008 | Dyson DC14 All floors Bagless Upright...
    Vacuums Logo
    114 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
