Question about Plumbing
Maax shower base installation - Plumbing
    Top Expert:
  • 3,698 Answers
Www.maax.com
Posted on Aug 20, 2014
  • 35 Answers
SOURCE: hi we just bought a maax breeze neo corner shower
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
Posted on Nov 19, 2009
heatman101
  • 43501 Answers
SOURCE: How do I install maax corner shower doors?
Here it is...
Be patient it is a large pdf file...
http://www.maax.com/Upload/docs/premium/technical/en/000_10014442_0904-2_E.pdf
heatman101
Posted on Apr 23, 2010
  • 1015 Answers
SOURCE: i bought a maax shower
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
Posted on Jan 30, 2011
  • 157 Answers
SOURCE: Some years ago I purchased
Hello. When you say basement side, I assume you are referring to the underneath. There are a number of options available, all hinge on the conditions you have.
1) Plenty Of Room: The best scenario. You can install a solid cross brace (preferably the same material as your joists) across spanning from one joist to another under the seam. Nail (best method - due to ability to handle potential shear stresses) cross brace in as secure as possible to the floor boards. Once that is done, lightly drive in a shim or two coated both sides with a little (this stuff goes a long way!) construction adhesive.
2) Same as Above, But Pipes Run Through: Either use a solid cross brace that will fit (ie 2x3) and treat the same as above, or use the 2x2 method where they are installed diagonally, but directly underneath the seam and shim. This should remove most of the squeak.
3) Not So Much Room, But Still Workable: (ie no pipes but limited access) Build an "H" frame that will span between joists, and the cross piece will do the same as #1. Secure in any manner you can, but ensure that it is secure on both sides of each support. Then shim and glue.
4) Can't Cross Brace: Not the greatest solution, but sometimes necessary. This one depends solely on the knowledge you have of the materials used... specifically their thickness'. Cut a piece of 5/8 inch (3/4 inch is better) plywood that will fit into the beam spaces under the seam. Be sure that they span about 6 to 8 inch on either side of the seam using screws (prefferably the kind meant for wet applications). NOTE: some shower bases are installed on a concrete/thin-set curb, this means that the screws must not penetrate the sub floor OSB. So, if your flooring material is only 5/8 inch, your overall screw length should not exceed 5/8 plus material used. (ie 5/8 + 5/8 is 1 and 1/4 inch maximum. Ideally 1 inch only) After all we only want the screws to hold. Before securing the brace, spread a good construction adhesive on it (I am a big fan of PL Premium).
If you are referring to the other side of a wall, and the shower is on the lowest level, there isn't much available in my experience. I have seen some similar issues involve: removing the silicone around the base and securing that. This involves drilling some of the material out on one side of the seam, filling with a two part epoxy, using heavy weights to secure the floor down, and shaping the epoxy smooth so the caulking will cover. This never does the job completely as access to the seam is limited.
These methods are a few suggestions that should help the issue. If they help out, please rate this answer a four thumbs-up. Thank you and good luck.
Posted on Mar 25, 2011
Testimonial: "This provides some new ideas for me to try. Your solution requires that I remove existing subfloor and re support the wooden floor. NOCANDO. but thank"
  • 157 Answers
SOURCE: Trying to install a Maxx
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Posted on Mar 26, 2011
Is there any problem with using silicone on maax mediterrian III shower walls
I looked at the installation instructions for mediteranean III at this Maax site. It says silicone sealant is to be used. Unsure where you noticed mentioned of siliconized latex.
http://www.maax.com/en/products/showers/showers-kits/mediterranean-iii-tm
Sep 04, 2014 | Maax Breeze: One Piece Round Shower...
I would just cut enough to install the pan by the way does the drain line hook to this pan? that will give it support as wwell
Apr 30, 2014 | Plumbing
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
I bought a maax shower base. i am going to intall a cement board on the wall, water proof it and then tile over it. The shower base has a flange that is 1/4'' thick. do i install the cement board on top of...
Jan 30, 2011 | Maax Acrylic Base for Shower - 102623
Trying to install a Maxx Neo-angle corner shower with prefab plastic base. No description as to how to affix the base to wall (no holes or tabs to screw into the studs)... Only instruction is...
Hope this helps.
Dec 14, 2010 | Maax Acrylic Base for Shower - 102623
I need to remove the Maax shower base and can not figure out how to remove the wedge retainer. do i need to actually cut the shower base to get the pipe detached to remove the shower base?
Hello, You shouldn't have to resort to that extreme. The drain unit that the retainer sits in is the part securing the base down, have a look at the diagram in this link: http://www.maax.com/Upload/docs/premium/technical/en/000_10014442_0904-2_E.pdf
The drain assembly should unthread and release the base. But sometimes they tend to work as designed.
The retainer is a compression fit (or should be... do you know the installer? they may have deviated from the described installation). Assuming a proper install, use a flat-head screwdriver and a utility knife to seperate the inside portion of the rubber seal of the retainer, from the plastic ring. The ring should now be able to be pried out, and the drain portion unthreaded.
If this helped, please rate a four-thumbs up. Thank You.
Nov 08, 2010 | Maax Acrylic Base for Shower - 102623
Does the styrofoam liner stay in the base of the round shower base?
If it fits flush under unit, yes, leave it there. It helps as a structural support for the floor.
It it stick out at all take it out as it is just packing material.
Hope that helps.
Feb 09, 2010 | Maax Breeze: Two Piece Round Shower Module...
Plumbing Logo
355 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
