My turn sansui turntable plays for a while then stops
I have a JVC turntable and an old Sansui reciever. Last night I was playing a record, and it stopped playing out of one speaker, and makes a loud buzzing noise. However, when I push the Mono button
You should check the connections to the turntable, it sounds like it might be feedback hum, caused by a wire touching or something like that. Don't forget to check the connections to the cartridge too.
Feb 09, 2014 | Audio Players & Recorders
Want to unlock sansui turntable p-l51
I don't know what you mean by locked, but if the table won't move and is locked in place, you probably still have the shipping screws in place. Remove the rubber mat and the platter. Under there, you will generally find red screws or screws with tags that must be removed to allow to platter to turn. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 04, 2013 | Audio Players & Recorders
My DA-T500 is stuck on Tape and wont change to turntable or radio
You might have a gummed up switch. Try some contact cleaner and go from there.
Apr 29, 2012 | Computers & Internet
I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
May 17, 2010 | Audio Players & Recorders
Have a Sansui compu edit p-m70 turtable. I turn
Lift off the turntable mat and the platter. Near the tone-arm, remove two screws holding down a panel and then inspect the tonearm belt. They wear out and stretch out and this could be the problem. Replacement is easy and does not require any special tools or further dissasembly.
Lock light indicates that turntable platter speed has reached correct speed.
Aug 21, 2009 | Sansui Audio Players & Recorders
I am repairing a Sansui XP99 that will just stop,normally at begining of LP record. Sometimes will play all the way through then stop. Will not repeat. Also tone arm lifter is not working
check the drive belt.the arm lifter will not work if there is not enough torque. lubricate the bushings in the motor,as the grease gums up after some years .
Aug 19, 2009 | Audio Players & Recorders
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
DRIVE BELT FOR SANSUI TURN TABLE
we need a belt for a Sansui turntable sr-2050c.
May 03, 2008 | Sansui Audio Players & Recorders
 Grubhead
Grubhead
