Question about Honeywell Heating & Cooling
Low battery voice warning - need to reset - already replaced batteries
RTH6300B1005 thermostat
SOURCE: Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Posted on Dec 30, 2008
billyvangogh
  • 108 Answers
SOURCE: everytime i replace the battery in my thermostat
Are the contacts dirty????? If so clean/sand them....if not it's likely an issue in the thermostat itself
Posted on Oct 25, 2009
  • 13 Answers
SOURCE: can you give me wiring diagram for honeywell
http://customer.honeywell.com/TechLit/pdf/69-0000s/69-1717.pdf that is the best I can give, as wiring is dependent on the type of equipment that you are controlling with the thermostat. Be sure to cut your power supply off before you start or you'll need a new transformer and a wiring diagram for your furnace too.
Posted on Oct 26, 2009
  • 146 Answers
SOURCE: I have had problems w/ my a/C and have had a
i would have to say replace the t-stat. did they change the filter. did they check the evap coil. did they clean the condenser coil. your supply temp should be at least 20 deg colder then your return temp. do you have an attic fan and is it working. is your unit over 15 years old the consider a system replacement. is the unit sized correct. every 400 sq foot of house you should have a ton of cooling. also can you feel drafts at your windows. all thing why your house could be warm. also check your ticket and see what your super heat was it should be 9-12 hope this helps.
Posted on Jun 05, 2010
  • 587 Answers
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Sep 26, 2010
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
I can't turn my olympus digital voice recorder WS-450S on, even with a new battery, i hadn't used it in a while, so i was shocked that it didn't work. It only turns on if i plug it in to the computer, but...
I've got this same problem :( Turns on when I plug it in to the USB, stays on when I disconnect it but if I turn it off I can't turn it back on again. It is showing a "battery low" warning and I tried to charge it via the USB last night, but it seems to stop charging after a while and despite being left for a good time last night, this morning it is the same and I've had another battery low warning.
I've just found the full pdf manual online, and have found (on page 80) a reference to it not always behaving stably when connected via a USB hub. I'm going to try to charge it via a direct port and see if that fixes it.
Oct 17, 2010 | Olympus WS-100 Digital Voice Recorder
Everytime i replace the battery in my thermostat it says low battery
Go to honeywell.com
Sep 22, 2010 | Honeywell Programmable Thermostat Heater
What does RFA 1 battery low mean?
The battery in your keyless remote #1 for the vehicle is low and needs replacing.
May 24, 2010 | 2003 GMC Yukon
Thermostat reset???
after you changed the battries did you check the set point. it is also possible that the batteries have ruined the stat
Aug 30, 2009 | Heating & Cooling
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
Low battery on hunter 44422
I have the same unit, 44422. The base has four clips, two on the top and two on the bottom. The front portion is clip-on. Try to push on the base's bottom and pull off the front portion, like opening a book. After the battery replacement you will have to reset the unit trough the little reset hole. Otherwise, the ''LOW BATTERY" will not go away. Yes, you will have to reprogram the unit.
Jan 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Erratic Low Battery Warning
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Nov 05, 2008 | Canon PowerShot A560 Digital Camera
Upright freezer
I went on a call for a problem like you explained. I looked everywhere and found that a battery in a smoke detector was low and warning that it needed replacing. No insult, but the customer and I were both were a little supprised. Now I have not found a fridge beep yet, so if you have already found the answer please let me know. So we can pass the answer on to others that have had the problem you listed. I realize our response time is late, I just saw it today. Please tell me what you found, Thanks, JT
Aug 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Heating & Cooling Logo
16 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
