Question about Kenmore Elite 31 cu. ft. Grab-N-Go Bottom-Freezer French-Door
Ice and water keeps coming out
Getting water or ice when cup removed water and ice keep coming out, and water is no longer cold
  • 46 Answers
Cup lever isn't returning to the off or close position completely. Suggest checking for rusty spring, dirty parts restricting lever and other parts there from moving freely. Could be the switches are worn out as well. Dis-assemble and clean all parts and inspect or replace old worn switches. Inspect ice drop/ flap door for mildew, sticky residue from drinks and ice build up.
Posted on Feb 09, 2014
SOURCE: No ice...different question
Are you able to see if you can push a Q-tip or something up the fill tube line to see if it's frozen up inside there. It happens on certain units. You may need to take the Ice Maker out (easy) to get to the fill tube.
Posted on Feb 27, 2007
fridgetech
  • 473 Answers
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Posted on Oct 18, 2007
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    SOURCE: Problems with Kenmore Side by Side Refrigerator
    I had the same problem twice, and both times I had to replace the Solenoid/value part. I went through the troubleshooting guide for the ice maker, which was nicely tucked in the front kick panel, and everything worked fine. It went through the cycles but still no water comes out. I finally had to follow the trail back to the solenoid/value unit. Remove the connectors and plug an A/C volt meter into the wires which go to the solenoid, run the cycle, and if you have 120 volts AC, you should have water coming out of the fill unit (assuming the line is not frozen).
    Here's the part I had to replace. again, twice in two years. Don't know if you have the same model, but good luck.
    http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=4389177&productGroupId=0046&supplierId=106
    Posted on Dec 04, 2008
    SOURCE: Ice maker not working
    I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
    Posted on Mar 31, 2009
    My fridge
    Turn temperature setting up!
    Oct 15, 2014 | Kenmore Refrigerators
    Water is frozen in fill cup inside the ice maker
    Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
    Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
    I have a Maytag fridge model # PSB2151GRW without the ice maker , there is a steady build up of ice on the bottom shelf of the freezer and a puddle of water on the floor ...
    Ok so here comes the fun part. Unplug the frig! Two people due this much faster. Remove all food and shelves from freezer. Get ya some bath towels place them on the floor and some on the bottom of the freezer. Take 2 coffee cups and heat them for 3 minutes. Remove them and remember they are hot! Pour a cup of hot water where the ice is and let the towel soak up any water. Now fill that up and heat for 2 minutes now. Pour the other cup on the ice and keep rotating until the ice is gone you will see the drain hole which is going to have ice down that tube so keep pouring hot water until the water drains into the drain pan below. If you can't clear the drain tube use compressed air or a turkey baster can help out too. Wipe down the inside of freezer walls to eliminate the condensation now your ready to party... Don't forget to plug the unit back in the outlet!
    Sep 26, 2011 | Refrigerators
    I have a Whirlpool White Conquest Side-By-Side Refrigerator GS6SHAXLQ03, manufactured March 2003. The ice maker creates ice and fills the "holding bin" on the interior of the door. However,...
    The ice will melt during the defrost cycle. Make sure your freezer is cold enough, at least -5, preferably -10. also, if your freezer is not full of food, put some milk jugs full of water in there to take up space. This will keep the temp colder when the compressor shuts off for the defrost cycle. if there is too much empty space, there is not enough mass to stabilize the temperature and keep it cold.
    Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Seems to make ice but will not keep it cold therefore it melts. It does this about 3 or 4 times a year but after staying off it will start working again
    The only thing that keeps the ice cold is the ice itself. If the icemaker isn't making ice fast enough then the ice will melt before more ice drops to keep it cold. In other words the motor ice the slower the ice melts. Now if the door gasket isn't sealing properly then the ice could melt to fast. Also the ice is going to melt some and when it does the water has got to drain out the bottom. If the water doesn't drain the ice will be sitting in water and will speed up the melting process dramatically. I hope this helps!
    Sep 28, 2010 | Scotsman DCE33PA1BC 15in Built-in...
    Water takes a couple of seconds to come out and not making ice
    Check the water supply lines feeding the refrigerator for crimps or hard turns and even if someone put a self taping tap valve as a shut off. They tend to restrict flow. If you find a tap valve remove it and have Tee placed there with a shutoff. It also does not hurt to pre-filter water going to the refrigerator. Lowes or Home Depot have some good in line filters that you just plug feed in one end and supply to fridge on other end. If it had air in the water you would have dripping all the time and noise of air rushing out once the dispenser valve is pressed. I am checking if your model has a filter somewhere. Have someone turn water off and disconnect the water feed from refrigerator and place lin in a pan or container and then have the turn it back on so you can visually see the flow. Disconnect power so if things get out of control water does not cover the electrical parts of the refrigerator. Let me know, Thanks Sea Breeze
    May 16, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
    Can't control the Temp. too cold/Ice-Machine over flow
    sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
    Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice maKer is not getting water but the water side works.
    Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
    Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    ACTUATER PAD
    Yes sounds like you need a new actuator pad. I had one do this this week and a new pad resolved it.
    Dec 07, 2007 | Maytag MSD2432G Side by Side Refrigerator
    Kenmore Elite 31 cu. ft. Grab-N-Go Bottom-Freezer French-Door Logo
    66 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    Jim Goldsmith
    Jim Goldsmith
    jackdo2
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
