Question about Motorola Mobility MING A1200
No audio on earpiece only
I can hear on speaker, i can hear the ringtone but when i pick up i cant hear the caller on the other line thru the earpiece
  • 3 more comments
  • cruella_m Nov 05, 2007
    I cant hear anything through the earpiece
  • GhettoCeleb Nov 06, 2007
    I too have that problem. One day the phone just stopped working. I can hear on speaker or if I use the headset but not when using the phone the normal way. Please Help!!!!
  • Anonymous Nov 15, 2007
    only speaker and bluetooth work to hear.
  • Anonymous Nov 16, 2007
    Yes. I see the same problem too. I cannot hear the other party using the normal way. I can only hear using the speakers or ear piece. It was working working for one year and then the problem came
  • Anonymous Dec 05, 2007
    I have the same problem as well - speaker works and headphones work, but I can't hear or be heard the regular way.
I have the same problem with mine! I have NO idea how to fix it. I've read through the entire manual and I still can't figure out how to fix it. If anyone knows how to fix this problem, PLEASE help!!
Posted on Oct 31, 2007
Incoming calls cant be heard. Caller can hear me but I cant hear them unless I put it on speaker
probably faulty earpiece, try to install SoundAbout and force the phone call audio to the earpiece, if that doesnt work, then the earpiece is brobably broken
Apr 11, 2017 | Cell Phones
Phone rings but cant hear caller they can hear me
This is a problem that has to do with the speaker of the phone(not your loudspeaker but the small one). It is probably broken and as a result, there is no way you can hear your callers.
One way to confirm this is for you to put your call on loudspeaker when it comes in and you have picked it, if you can hear your caller then you are sure that the smaller speaker is faulty.
Also, you can try to use a very compatible earpiece or headset and see if you can hear your callers.
If this happens to be the case there is only one way you can get this to work and that is by sending it to a qualified repairer as the phone requires serious expertise so as not to damage it an further.
hope this solution helped solve your problem? please comment for more information and thank you for using the fixya.com website
Jan 01, 2011 | Pantech Duo Smartphone
I CANT HEAR THE CLEAR VOICE OF RECEIVED CALLER
Hello there,
There are two ways on how you can hear the caller. One is through the earpiece and one is through the phone's speaker.
Are you able to hear the caller but just not clear or with static sound? If yes, then you have a problem with the earpiece of your phone. You can test this by putting it to a speaker phone. If you can hear the caller clearly then you should have your earpiece check. Usually this problem is caused when the earpiece is often moisted or get wet. Try blowing a canned air on the earpiece.
Please let me know how this goes. Thank you for using FIxYa.
Nov 22, 2010 | Cell Phones
My samsung mobile SGH E210 has a problem All incoming sounds and other sounds of mobile are not coming. I cant hear even my default ringtones. Kindly help me.
Possible that the speaker is faulty, the earpiece could have worned out. So best is to open and check the speaker for continuity , if not the earpiece must be changed with the same type.
If this is ok then the audio amp output can be faulty /dry soldered.
Sep 14, 2010 | Samsung Cell Phones
I have a Motorola i776w i must put the caller on Speakerphone or use an earpiece to get audio.
Hi, when you start using a phone with speaker and earpiece,it means that the earpiece inside the phone that allows you to hear others when they call you is faulty,and you will need to replace it,for you to stop using the speaker.
Take care.
Jul 02, 2010 | Motorola Mobility i776 Cell Phone
Can't hear callers voice unless phone is put on speaker phone. The built in hearing piece dosen't seem to work? Is this a setting problem
This is not a setting problem, the problem is that the earpiece of your phone is bad that is why you cannot hear callers voice.
The speaker you put it is for the ringer, it does not have anything to do with earpiece and you can hear your caller through it.
To fix your earpiece problem because you cannot be putting your phone on speakers always because atimes you will want privacy.
To fix the earpiece problem, you will need to replace the earpiece on your phone in other for you to hear your caller. just change the earpiece as advice and you will see that the problem is solve.
Take care.
Jun 03, 2010 | Samsung SCH-u740 Cellular Phone
The earpiece and speaker will not work. the other caller can hear me but i cant hear them
Since you said your other caller can hear you but you cannot hear them, it means the earpiece of your phone is bad and will need to be replaced.
Change the earpiece and you can hear your caller easily.
Take care.
Apr 19, 2010 | Motorola Mobility CLIQ Cell Phone
I can't hear the caller but the caller can hear me!
just need a new earpiece speaker or it simply needs to be adjusted into place. If there is no repair shop around you or you do not want to mess with it, then just buy a $20 bluetooth headset to bypass the whole earpiece.
Mar 10, 2009 | Palm Treo 650 Handheld
Cant hear person talking to me
I think the earpiece has become disconnected either in the curly lead or in the handset.
Oct 06, 2007 | Motorola Mobility RAZR V3
Can't hear caller
The earpiece speaker has gone bad. Unless you have access to a replacement speaker and can solder you will have to take the phone to you nearest Motorola service center.
Sep 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MING A1200 Logo
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
