Question about Panasonic TC-32LX60 32 in. LCD Television
Hdmi not working
My hdmi stop working
My Iomega mx mobile mass storage player has stopped sending signal through HDMI cable to TV all other functions are ok. HDMI cable changed still no picture
You need to try some tests.
  • Does the same cable work with any other TVs
  • Do any other devices work on your existing TV ?
You also need to check that you have set the output of your device to HDMI and the input of the TV to HDMI. In the past the TV may have automatically selected HDMI when the device is turned on but sometimes that does not work.
Mar 23, 2014 | Iomega Computers & Internet
JVC hdmi not working
Check the HDMI settings.
Mar 17, 2013 | Televison & Video
Toshiba 42hp84 hdmi stopped working. I have tested the HDMI cable on other TV and it is working fine but don't know why it stopped working on my toshiba.
I would suggest you see if your hdmi device outputs on another tv.
If it does, it looks as if the hdmi input on your tv is defective.
Getting it service isn't exactly cheap, but it's cheaper to service the tv than to replace it.
Mar 08, 2011 | Toshiba 42HP84 42 in. Plasma HDTV
Hdmi inputs does not show a picture. The inputs just stop working.
I'm having the same problem. The projector stopped recognizing any input over either of the two HDMI inputs. The JVC RX-D411S receiver was working fine up until I used the VGA input with a computer and since that time, HDMI has not worked (despite working fine before). I tested two HDMI cables into each of the two ports but nothing! All other inputs work fine.
Jun 28, 2010 | Panasonic PT-AX200U Projector
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
HDMI PORT STOPPED WORKING!!
the best option here is connect via a standard PS2 avi cable or componet cable until your tech guy comes out!
Apr 30, 2009 | Televison & Video
On my PT-50DL54 the HDMI HDCP stopped working
Try unplugging the television for 10 or 15 minutes and try again.
Apr 30, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic TC-32LX60 32 in. LCD Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
