Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Lg lfx25960st ice maker not making
Very little water going to ice maker. Plenty of water going to water dispenser. Have removed filter assembly and cleaned and sucked water through. So it seems the problem is between the filter and ice maker. It is like the water turns off too early thus there is not enough water to make ice. how do I check that tube going to ice maker? I have taken out maker and could not get to tube that fills ice maker thanks
  • 489 Answers
SOURCE: ice maker
It is possible that the water valve behind the refrigerator is either defective or the wire connection is loose.  Also check the fill tube where the water comes in and see if there is ice blocking the fill tube.  Since it's under warranty, have it serviced by the LG warranty to resolve this issue.
Posted on May 11, 2008
  • 489 Answers
SOURCE: LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
  • 489 Answers
SOURCE: water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
Posted on Jun 08, 2008
  • 489 Answers
SOURCE: Ice door flapper does not open
It is possible that the solenoid wire connections may have come loose.  You will have to pop off the front cover of the display panel to gain access to the solenoid.  To remove the panel, look below the bottom of the panel to find 2 screwdriver holes.  Slide a screwdriver in one of them and gently pry open the panel.
Posted on Sep 30, 2008
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
How to know the water pressure is wright for Samsung ice maker imc701
Used machine? If new seller needs to help. If under warranty check the MFG customer service number.
If used this may be the reason it was sold. If Used there is a possibility the water filter needs to be replaced. Yes they'[re expensive, but they can interfere with the process. Does the Cold water device work? Is there plenty of flow? If so it's not filter or pressure. If it barely comes out, then it's probably filter and may be the ice maker issue.
Feb 27, 2015 | GE GFSS6KKXSS Bottom Freezer French Door...
My LFX25960st LG stainless refrigerator ice maker isn't working, it'll make a few ice cubes every couple of days and now on the touchpad it says ER IF and i can't touch anything, how can i fix my problem?
Remove the fresh water hose coming into your refrigerator and check the water flow with a small bucket. This actually sounds like a replace water filter error. Some IF error codes break down to Inline Filter.
Jul 31, 2010 | LG LFX25960ST Stainless Steel French Door...
Water dispenser and ice maker don't work
You have a bad water filter housing. Be sure to turn of the water to the refrigerator before replacing this part. Replace the filter at the same time.
Apr 30, 2017 | Whirlpool GS6NBEXR Side by Side...
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
No ice
IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Need part number for dual-valve water pump
Ok, you are correct. there is a dual valve assembly and the number is 5220JB2008A.
Please rate and god bless:)
Apr 24, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
52 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
