Question about 2008 Chevrolet Silverado 1500 Pickup
Misfire on cylinder 1 and 7 - 2008 Chevrolet Silverado 1500 Pickup
  • Chevrolet Master
  • 753 Answers
Check spark plugs, wires & coils for those cylinders,try moving plugs or wires to see if misfire follows them if they all check out then chk injectors
Posted on Sep 16, 2014
#1 cylinder is misfiring, put new fuel ejector and the problem is still there.It has a bad noise in the motor.
Thread: Cylinder 1 misfire P0301 - The Chrysler Minivan Fan Club ...
forum.chryslerminivan.net/showthread.../27978-Cylinder-1-misfire-P03...
Feb 6, 2013 - 7 posts - ‎4 authors
My mother-in-law's 2002 Town and Country has the P0301 cylinder 1 misfire error code. I haven't done much work on this type of car, so I'm not ... '05 Town & Country Cylinder 1 misfire mystery
Feb 3, 2014
Engine misfire
May 6, 2012
#1 Cylinder misfires at idle only
Jun 4, 2011
Running rich / Misfire Mystery
Sep 20, 2010
More results from forum.chryslerminivan.net
Part 1 -How to Test the Coil Pack (2001-2008 Chrysler 3.3L ...
easyautodiagnostics.com > Chrysler > 3.3L, 3.8L
Apr 29, 2011 - Page 1 of 7: How to Test the Coil Pack (2001-2008 Chrysler 3.3L, 3.8L). ... This article will help you troubleshoot a Misfire Condition that might be setting ...your 2001-2009 Chrysler (or Dodge) 3.3L or 3.8L Town and Country, Voyager, ... it's important the you know what 'Paired Cylinders' and 'Non-Paired ...
Jan 03, 2016 | 2001 Chrysler Town & Country
Check engine light code p2196,p2197, po300 ,304,305,306,p2 ,Im freeking out.
P0300 Random/Multiple Cylinder Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0305 Cylinder 5 Misfire Detected P0306 Cylinder 6 Misfire Detected P0307 Cylinder 7 Misfire Detected P0308 Cylinder 8 Misfire Detected P0309 Cylinder 9 Misfire Detected P0310 Cylinder 10 Misfire Detected P0311 Cylinder 11 Misfire Detected P0312 Cylinder 12 Misfire Detected P0313 Misfire Detected with Low Fuel P0314 Single Cylinder Misfire (Cylinder not Specified) P0315 Crankshaft Position System Variation Not Learned P0316 Misfire Detected On Startup (First 1000 Revolutions)
Read more at: http://www.obd-codes.com/trouble_codes/
Copyright © OBD-Codes.com
P2195 O2 Sensor Signal Stuck Lean Bank1 Sensor 1 P2196 O2 Sensor Signal Stuck Rich Bank1 Sensor 1 P2197 O2 Sensor Signal Stuck Lean Bank2 Sensor 1 P2198 O2 Sensor Signal Stuck Rich Bank2 Sensor 1
Copyright © OBD-Codes.com http://www.obd-codes.com/p0002
May 07, 2015 | 2006 Ford Taurus SEL
2003 acura tl error codes po301 po302 po304 po306 p1399 po300
PO300 and P1399 are random cylinder misfire detected.
PO301 cylinder 1 misfire
PO302 cylinder 2 misfire
PO304 cylinder 4 misfire
PO306 cylinder 6 misfire
I would say that you have damage to the ignition wiring harness or you ECM is failing.
Feb 17, 2015 | Acura Cars & Trucks
I would like to know what these codes mean
P0171 System Too Lean (Bank 1)
P0174 System Too Lean (Bank 2)
P0301 Cylinder #1 Misfire Detected
P0302 Cylinder #2 Misfire Detected
P0304 Cylinder #4 Misfire Detected
P0306 Cylinder #6 Misfire Detected
Mar 12, 2014 | 1999 Ford Explorer
PO016, PO300, PO420, PO442 codes
your engine is misfiring according to your codes ...4 codes 4 problems
P0300 - Random Cylinder Misfire DetectedP0301 - Cylinder 1 Misfire DetectedP0302 - P0312 Cylinder X Misfire DetectedP0325 - Knock Sensor 1 Circuit (Bank 1)Just showing a few
Oct 23, 2013 | 2003 GMC Envoy
Cylinder misfire
misfire,
only on cylinder #1
bad spark plug or wires to it or COP coil to it.
bad injector
bad injection signals
low compression on #1
there are simple tests for each, i will not ever guess on misfire.
misfire means, in English (not slang)
THIS Cylinder #1 had weak power during the POWER stock.
The ECU computes Velocity of each power stroke and Reports the weak.
even an air leak to #1 intake runner can cause this
or the injector #1 base gasket leaking. Air.
but it is not fibbing it is weak. #1
Oct 20, 2013 | 1996 Chrysler Cirrus
CODES-PO301-PO303-PO316- CHANGED PLUGS & WIRES. STILL MISS ON START UP, GOES AWAY MOST OF THE TIME ABOVE 1000 R.P.M
P0301 - Cylinder 1 Misfire Detected.
Causes:
- Improper spark plug at cylinder #1
- Insufficient compression at cylinder #1
- Incorrect fuel pressure
- The injector circuit is open or shorted at cylinder #1
- Fuel injector #1 may be faulty
- Intake air leak
Solutions:
- Perform Injector Service
- Replaced Spark Plug #1
- Replaced Injector #1
- Replaced Ignition Coil #1
P0303 - Cylinder 3 Misfire Detected.
Follow info from P0301.
P0316 - Misfire Occurred In The First 1,000 Engine Revolutions.
Causes:
- Damaged CKP sensor.
- Ignition System.
- Fuel Injectors
- Running out of fuel
- Fuel Quality
- Base engine
- Damaged Powertrain Control Module
Solutions:
Usually the P0316 is combine with a P03XX codes. The P03XX code indicates in which cylinder the misfire occurred.
Jan 17, 2011 | 2002 Mercury Sable
05 kia amanti with diagnostics codes p0350,p0320,p0300,p0302,p0303,p0304,p0305,p0306.skipping at times.when it does skip & misfire the rpm gauge goes crazy.this problem is not consitant
Generic OBD II Diagnostic Trouble Codes
DTC CODES P0300 to P0399
P0300....Random/Multiple Cylinder Misfire Detected
P0301....Cylinder 1 Misfire Detected
P0302....Cylinder 2 Misfire Detected
P0303....Cylinder 3 Misfire Detected
P0304....Cylinder 4 Misfire Detected
P0305....Cylinder 5 Misfire Detected
P0306....Cylinder 6 Misfire Detected
P0307....Cylinder 7 Misfire Detected
P0308....Cylinder 8 Misfire Detected
P0309....Cylinder 9 Misfire Detected
P0310....Cylinder 10....Misfire Detected
P0311....Cylinder 11 Misfire Detected
P0312....Cylinder 12 Misfire Detected
P0313....Misfire Detected with Low Fuel
P0314....Single Cylinder Misfire (Cylinder not Specified)
P0320....Ignition/Distributor Engine Speed Input Circuit
P0321....Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322....Ignition/Distributor Engine Speed Input Circuit No Signal
P0323....Ignition/Distributor Engine Speed Input Circuit Intermittent
P0324....Knock Control System Error
P0325....Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
P0326....Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327....Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328....Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329....Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
P0330....Knock Sensor 2 Circuit (Bank 2)
P0331....Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332....Knock Sensor 2 Circuit Low Input (Bank 2)
P0333....Knock Sensor 2 Circuit High Input (Bank 2)
P0334....Knock Sensor 2 Circuit Input Intermittent (Bank 2)
P0335....Crankshaft Position Sensor A Circuit
P0336....Crankshaft Position Sensor A Circuit Range/Performance
P0337....Crankshaft Position Sensor A Circuit Low Input
P0338....Crankshaft Position Sensor A Circuit High Input
P0339....Crankshaft Position Sensor A Circuit Intermittent
P0340....Camshaft Position Sensor 'A' Circuit (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor 'A' Circuit Range/Performance (Bank 1 or Single Sensor)
P0342....Camshaft Position Sensor 'A' Circuit Low Input (Bank 1 or Single Sensor)
P0343....Camshaft Position Sensor 'A' Circuit High Input (Bank 1 or Single Sensor)
P0344....Camshaft Position Sensor 'A' Circuit Intermittent (Bank 1 or Single Sensor)
P0345....Camshaft Position Sensor 'A' Circuit (Bank 2)
P0346....Camshaft Position Sensor 'A' Circuit Range/Performance (Bank 2)
P0347....Camshaft Position Sensor 'A' Circuit Low Input (Bank 2)
P0348....Camshaft Position Sensor 'A' Circuit High Input (Bank 2)
P0349....Camshaft Position Sensor 'A' Circuit Intermittent (Bank 2)
P0350....Ignition Coil Primary/Secondary Circuit
Nov 17, 2010 | Kia Amanti Cars & Trucks
WHAT IS THE CAUSE OF THE PO301 CODE?
The error code p0301 ,This code is related to misfire.The cylinder is misfiring. p0301 this is the indication of cylinder number 1 ,that is misfiring.If the code comes up as p0300 this is the indication of random misfire from all the cylinders.But in your case its indicating p0301 this is indication of cylinder 1 misfire.Check cylinder 1 and replace the faulty cylinder 1 to clear the fault.The spark plugs and the wires connecting to spark plugs also needs to be checked. Keep updated with any more query.Thanks.
Oct 12, 2010 | 2003 Mitsubishi Lancer
I have 1996 Dodge Gran Caravan, and it gives me these codes: 27 and 43, what do they mean??
CODE 27 - Injector Control Circuit, output driver does not respond properly to the control signal
Code 27 MIL light options: OBDII
P0201 - Injector #1 Control Circuit
P0202 - Injector #2 Control Circuit
P0203 - Injector #3 Control Circuit
P0204 - Injector #4 Control Circuit
P0205 - Injector #5 Control Circuit
P0206 - Injector #6 Control Circuit
CODE 43 - Cylinder Misfire, or Ignition Primary Circuit
CODE $# MIL options: OBDII
P0300 - Multiple Cylinder Misfire
P0301 - Cylinder #1 Misfire
P0302 - Cylinder #2 Misfire
P0303 - Cylinder #3 Misfire
P0304 - Cylinder #4 Misfire
P0305 - Cylinder #5 Misfire
P0306 - Cylinder #6 Misfire
P0351 - Ignition Coil #1 Primary Circuit
P0352 - Ignition Coil #2 Primary Circuit
P0353 - Ignition Coil #3 Primary Circuit
Feb 03, 2010 | 1996 Dodge Caravan
2008 Chevrolet Silverado 1500 Pickup Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
