Question about Stairmaster 4600 Cl Cordless Freeclimber
Need to change the blueface touchpad.. Any videos available for support?
My machine is working fine.. i purchased the touchpad becuase the functions are not working;unable to put in my age, weight so that I can get an accurate calorie burn count..
  • Stairmaster Master
  • 918 Answers
Follow the steps in this video. It does not show the removal of the overlay, but gets you all the way to the point of simply peeling the old overlay off and sticking the new one on.
C40 Console Repair Video for Stairmaster Steppers
Posted on May 09, 2014
Scroll bar
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
Feb 03, 2013 | Acer Aspire Computers & Internet
Flases f 21 code worked fine untill i put new front board in and i cleaned out lines and hose still giving f 21
I looked at your tech sheet. As you already know the F-21 on your machine has to do with touchpad not communicating with control. F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
If you have a new touchpad installed and the harness is fine then the control must be bad.
Apr 01, 2011 | Maytag EPIC MFW9600S
How to change touchpad settings for lenovo g550, I hate this touchpad, please help
You really can't do much with settings for a touchpad. I would recommend disabling it and using a wireless mouse. var fctb_tool=null; function FCTB_Init_c6f64f985d3644929e3995eea1c55206(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d35d1f3861484992b99b0e9345d90151(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | Lenovo G550-29583AU Notebook
I have a Dell Inspiron 1545, purchased about an year ago. My OS is Windows 7 Professional 32 bit. The touchpad is not working. I have reinstalled the official driver, but to no avail.
Reboot and enter your bios (instructions are on the boot screen), reset your bios to defaults. If you're using a synaptics touchpad, they're a bit finicky and you need to remove your existing software in the control panel and install a fresh copy of it.
Dec 30, 2010 | Dell Inspiron 1545 Notebook
My touchpad works but not its multi gesture its emachines D730
most touchpad drivers will work on windows 7 but the program which control the functionality of the touchpad "Synaptics" or ALPS" pointing device may not be compatible in win7 this is an issue with most computer manufacturers but not their fault since win7 is a new operating system and possibly in the near future who knows when windows will come with a windows update to make touchpads work in windows having all it's functionality available.
try calling your computers maker and ask if they have work arounds for your touchpad some may have options to make all your touchpads functionality work but some may not try calling them and have them check it for you, they should know better since they are trained for the specifics of your system.^_^
Jun 15, 2010 | eMachines eMD620-5133 Notebook
Touchpad tapping is not working
You need to download and re-install touchpad drivers to get the tapping function working.
You can download the touchpad drivers from the link below:
http://blogntech.com/download-lenovo-ideapad-s10-xp-driver.html
May 09, 2009 | Lenovo IdeaPad S10-1208U Netbook
Scroll function on my Toshiba Satellite TouchPad isn't working
I would go to this link and select your device and download the driver/software for your device. Try to reinstall the driver/software.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&cm_sp=Sitemap-_-Support-_-DriversDownloads
Note:
Fn-F9 is a hot key combination that will enable/disable the touchpad.
Feb 14, 2009 | Toshiba Satellite Pro P300 Notebook
Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
I hope the drink did not damage the touchpad.(it is heat senstive)
if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
Nov 13, 2008 | Dell F3534 Touchpad
Touchpad Not Working
is there a touch pad 'switch' off function with this particular model? Some Acer machines have an F number plus another key to de-activate/reactivate touch pad. Check your Manual
Jun 19, 2007 | Sony 4-660-223-01 Touchpad Keyboard
Open Questions:
Stairmaster 4600 Cl Cordless Freeclimber Logo
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
