Question about Husqvarna Garden
254xp Decompression valve leaking - Husqvarna Garden
    Master:
  • Husqvarna Master
  • 645 Answers
These valve are not serviceable, if leaking, it will need to be replaced.
Posted on Feb 03, 2016
Check valve falls out leaks gas 2000 141 EPA PH1
The decompressor valve is a complete assembly and not a serviceable component. These valves are readily available and many reputable Husqvarna shops will carry them in stock.
To replace one, use a long tube socket and unscrew it. Replace in the same manner.
Mar 27, 2014 | Husqvarna Chainsaw Decompression Valve
Is there a decompression valve on a 2005 660 Yamaha Grizzly?
Most likely not and if there was it would be built into the valves/cam or you wold have a lever you would need to operated the decompression valve just to start it normally with the starter...
Dec 29, 2013 | Grizzly Big Bear Atv Maintenance Free...
268 stuck decompression valve
You can remove the decompression valve,it just screws into the cylinder. You can either replace if its broken or you can blank them off.
Aug 07, 2013 | Husqvarna Garden
Wont kick over
Does the decompression valve operate when the lever is moved? As the engine turns over easily with the plug out, but not with it in, I would have to suspect the decomp valve,
May 17, 2013 | Yamaha YZ 450 F Motorcycles
Husqvarna 345 decompression valve
The345 should have a blue push in deco valve on the r/h side of the cylinder, if not there may be a 13mm blanking screw there, this can be removed and a deco valve fitted.
Dec 24, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Have a Husky 254xp and I have to consantly readjust h&s needle valves back to their reccomened settings even after 1or 2hrs use. Suggestions? Brian
When you say re adjust back to basic settings, are they actually vibratinh out? it maybe the springs have become weak and allowing them to move due to the vibration of the saw.
May 14, 2011 | Husqvarna Forest & Garden No.967012396 345...
Decompression problems --cam shaft looks in good condition but it is not decompressing when turning over,the valves have been set at tdc @ .15 mm ,the cam is stock pn # 58436010044 the cam is sold as an...
the valve clearance is incorrect at .15mm ( .005") it should be at .010"inlet and .012" exhaust and is set on tdc but on compression stroke tdc
decompression cams have a special grind that holds the valve open for starting revolutions and as the engine rpm picks up the cam follower doesn't follow the profile any more and closes the valve
engines that utilize such a cam are motors that have a rating exceeding 3 hp on a rope pull otherwise , the piston cannot be pulled over compression past enough to get it started
5 hp lawn mowers , 10-20hp rope pull generators etc have this cam
Dec 09, 2017 | 2003 KTM 625 SXC
Getting my 2001 yz 426 started
hold the decompression lever in and kick it slow then let go of the decompression lever and give it a good kick without using the decompression lever.
Nov 29, 2008 | 2001 Yamaha YZ 426 F
Garden Logo
103 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
