Question about HP PSC 1410 All-In-One InkJet Printer
Printer Hi my printer prints when ever time it chose to and having problem showing me the sign of error botton in which its nothing to do with paper jam itz only telling me that how many printing awaiting. The printer is not 2 year old as yet the model is : HP PSC 1410 i appriciate your help please thanks
  • 4,402 Answers
Posted on Dec 17, 2007
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Paper Jam Error
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 14, 2007 | Canon PIXMA iP1600 Printer
HP PSC 1410 All-In-One InkJet Printer Logo
47 people viewed this question
Ben Johnson
