Question about Kenmore Refrigerators
Overflowing non removable drain pan
25361502404
SOURCE: Drain pan fills daily
does drain pan have copper lines it
Posted on Mar 05, 2008
lenwest
  • 150 Answers
SOURCE: Have the Kenmore Elite commercial refrigerator,
Try a sponge using gloves.Add hot water and continue with the sponge.
Posted on Feb 21, 2009
  • 3 Answers
SOURCE: Drain pan of refrigerator is filling up and overflowing onto the floor. This never happened before.
Maybe it is because of increased humidity inside the fridge. This could be caused by the door not being properly closed or leaking.
Posted on May 31, 2009
SOURCE: drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Posted on Jul 31, 2009
aasc
  • 1606 Answers
SOURCE: drain pan over flowing
The rubber seal on the water filter is bad . Replace the filter in the bottom kick plate . When the filter goes bad , water will drip into the drain pan , causing it to overflow .
Posted on May 12, 2010
Why does drain pan overflow? How is water in pan suppose to go away before overflowing?
Are you sure it is the drain pan overflowing? If water is appearing on the floor every few days, it may not be getting to the drain pan (evaporator tray), due to a blocked drain channel. The evaporator tray will normally cope with the daily amount of de iced water of a frost free fridge/freezer.
Mar 07, 2015 | Refrigerators
DRAIN PAN FULL OF WATER AND OVERFLOWING ONTO FLOOR
What kind of unit do you have? Its possible depending on the manufacture that a water line is the cause as it drips water into the pan causes the overflowing of the drain pan. Look for cracks in all the water line under the unit and you may have to remove the back and the water valve to see it. Good luck
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
Why is my drain pain overflowing?
on most fridges, you should be able to empty drain pan. Remove grill on bottom at the floor, and see if pan will slide out. Good-Day!
Jul 26, 2014 | Roper Refrigerators
How to access drain pan
The panel at the bottom (kick panel) is removable. The pan is located inside. The water on the floor may indicate that the pan has overflowed or it may have cracked
Dec 28, 2012 | KitchenAid KSRD25FK Side by Side...
Drain Pan overflowing and water is leaking in refrigerator I can see drip pan overflowing but I do not know how to get to it
remove the back panel inside the freezer,then defrost the pan,then take a length of stiff wire and clear out the drain line from there down to the pan in the lower area near the compressor,as theres probably lime,mold growth build up in the drain line plugging the hose restricting draining of defrost water
Mar 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Lower reservoir is overflowing.
I am assuming its the lower drain pan overflowing. Remove screen and check if anything blocking exit hole. If not then check plumbing underneath drain pan for stir stcks, broken glass, or bottle caps.
Jun 13, 2010 | Moyer Diebel 25 in. DF Free-Standing...
I have a miele G841 dishwasher and the saftey pan is always filling up with water and then a intake - drain error code comes up and the dishwasher will not allow water to enter for rinse until I drain...
Hi dear.If you are handy enough,that's what you can check to make a solution for yourself.Goodluck.
Check all hoses, connections and threaded unions for leaks.
Note:
If the leak source has not yet been detected, check the following areas
in the toekick and the drip pan for wear and tear:
�� Connection between the circulation pump and the sump
�� Axial face seal of the circulation pump
�� Connection between the drain pump and the sump
�� Connection between the salt container and the water intake
�� Connection between the water intake and the cabinet side wall
�� Overflow (e.g., excess foam formation)
�� Water level between the overflows (�� seating of the lower door seal?)
�� Connection between the cabinet and the salt container
�� Non-return valve in the sump (�� water running back from the drain hose?)
3. Check overflow float switch B8/3 for continuity and correct operation.
4. Carefully dry all electrical components in the drip pan area.
Cause:
Float switch defective.
Remedy:
Replace overflow float switch B8/3.
I hope that helps.Thanks.
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Drain pan keeps overflowing
sounds like the drain be be getting clogged. you will have to find the tube, remove mounting screws and bracket and blow out with compressor or pipe cleaner
Apr 15, 2009 | GALAXY Microsystems 25.4 cu. ft....
Drain pan
Oct 24, 2008 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
Refrigerators Logo
16 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
