Question about General Electric PVM1870SMSS Microwave Oven
Keypad shorted - General Electric PVM1870SMSS Microwave Oven
Model Psa1201rss01 key pad shorted msg. Does it need both the main control and keypad control panel?
The keypad must be replaced, it is shorted just as the message states.
Feb 15, 2017 | Microwave Ovens
How to get the 5E error off my display on my kenmore microwave
fix it.
SE Shorted key 1. Check if cable of keypad has been inserted into connector of main PCB. 2. Check for short between main PCB and connector or keypad and cable. 3. If there is not a problem with connector on main PCB and cable of keypad, replace the main PCB.
Jan 22, 2016 | Kenmore Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
Dec 14, 2012 | GE Profile PVM1970SRSS 1.9 Cu. Ft....
Model JES1451DN1BB Service May Be Needed Keypad Shorted
If the keypad is shorted it will need to be replaced, also! the control board should be checked.
Jun 28, 2012 | Microwave Ovens
Microwave keypad shorted
looks like your buying a board unfortunately not worth the repair get a new microwave boards cost way to much
Nov 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave beeping and says keypad short may need service
the membrane gets dirt under them and shorts out the keypad,you may as well just replace the control board which includes the display and keypad on the same board
Jul 26, 2010 | GE JVM1850 1000 Watts Microwave Oven
Microwave is beeping, lock comes on, F2, just keeps beeping by itself
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
Sep 08, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Heard on news of fires even when off
That's usually form shorted or shorting keypads.
What to look out for is is you get an F3 error on your keypad (assuming you have a GE - the code is different on other brands).
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls or short the keypad.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
Or just to be safe, you can just leave the oven's door open at night or actually any time you're not using the oven..
May 24, 2009 | GE Spacemaker JVM1740 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
General Electric PVM1870SMSS Microwave Oven Logo
Top General Microwave Ovens Experts
William Miller
William Miller
ken skalski
Steve Mason
Are you a General Microwave Oven Expert? Answer questions, earn points and help others
