Question about New & Popular 5-0 Radio Pro Police Scanner
It disappears when booting up
When i start it you see the smartestapp.com screen then it all disappears
Keyboard keep disappearing. How do you do a hard reset on it?
keyboard disappearing while typing?? - Android Forums at ...
forums.androidcentral.com > ... > Verizon Droid Forums > Droid RAZR
Jul 16, 2012 - 17 posts - ‎14 authors
Just started today. Mid text, while typing, the keyboard part of the screen will justdisappear back to the bottom of the screen. touch it to type. LG L34C Optimus Fuel Android Net 10 phone keyboard ...
1 post
Aug 4, 2015
Sony keyboard keeps disappearing
Sep 11, 2013
Galaxy S4 On Screen Keyboard-RESOLVED
Jul 27, 2013
Stock Keyboard disappears when typing...
Aug 4, 2011
More results from forums.androidcentral.com
Jan 01, 2016 | Tablets & eReaders
Wont boot up
You should kindly explain how it started, what happened and symptoms you see.
Try this:
1. When you try booting and you can see your operating system (OS) e.g 'Windows Vista' appearing on the screen and not giving you a successful booting, then repair repair Windows or formating using your Operating System software.
OR
2. When you try booting and you can't see anything on your screen or not even a sign of booting, try and confirm if your motherboard is still good. And if bad a pin board can be fix and pinless board unfixablr.
Jun 10, 2011 | Computers & Internet
My screen goes off when windows xp starts the boot process
Does the display come back at all?
Is it the same on an external monitor?
As soon as BIOS screen disappears press F8 multiple times until a text menu appears allowing you to to select SAFE MODE. Select SAFE MODE.
DO you get a display now?
Can you select 1024x768 resolution and get a display, if so, rebot and try a normal boot.
May 16, 2010 | Acer Computers & Internet
My ibm laptop, was working great until this morning, the screen started to flicker, then the icons started to dim and completely disappear and then the screen went to a coloured test pattern and finally...
Check the power supply.Hope the notebook receives power from the battery or the Ac adapter.We need to ensure there is no issue with the power supply.boot the notebook to the safe mode.If it boots to the safemode perform a system restore.In case the notebook does not boot to the BIOS,connect to an external monitor.If we still do not get a display,its the video card
Mar 02, 2010 | IBM ThinkPad T40 2373 Notebook
Windows XP Start up
Dear! You have to go in BIOS setup and choose boot utility and then select silent boot if it will enable you have to disable or if it will disable it will have to enable. Your problem will solve.
Aug 01, 2009 | Computers & Internet
All of the icons from the screen disappeared!
try to reboot your computer into safe mode.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Then click start
click run
type in msconfig
uncheck everything under the startup tab except your antivirus
and reboot
Jun 05, 2009 | Computers & Internet
On boot up screen reads "Loading PBR 2...done"
As the notebook is starting you see the Dell 'Splash' screen. Press F2 to go into the BIOS setup. Check to make sure two things: first that your cd/dvd and hard drive are being recognized and identified, second that your boot order has the cd/dvd first and internal hard drive second. Your machine may be trying to do a USB device boot or network boot when these options are not available. Next try pressing F8 immediately after the splash screen disappears to try to get into Safe Mode. If it still fails to boot, I would try booting using a Windows XP installation disk and then going into the repair console to check if the hard drive is damaged or corrupted.
Dec 15, 2008 | Dell Inspiron 6000 Notebook
Desktop disappears after booting
sounds like a blown operating system. got a recovery disk handy?
May 04, 2008 | Dell Latitude D600 Notebook
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
New & Popular 5-0 Radio Pro Police Scanner Logo
27 people viewed this question
Top New & Popular Apps Experts
Bill Boyd
ray gallant
Are you a New & Popular App Expert? Answer questions, earn points and help others
