Question about Miele S514 Solaris Electro Plus Vacuum
Bag indicator indicates full, empty bag, poor suction
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Posted on Jan 17, 2008
renevacdoc
  • 84 Answers
SOURCE: no suction
well, it actually sounds like there is a blockage. Try removing your hose and dropping something through it, like a quqrter. If it comes through, no clog. If it is clogged, I believe that machine has a blower on the upper part of the cleaner (maybe in the bag compartment towards the top. You can take out the filter holder and plug the hose in there and run the unit . Does the blockage come out? If not, Try shaking the hose, or you can put a stiff wire in it to try to free it. Do not run water through it. If there is no blockage at all, then you will probably need to take it to a service center. But I am pretty confident that we are looking at a clog situation. Let me know if this fixesya! Thanks, Rene (vacuum Doctor)
Posted on Nov 15, 2009
Bruce Boogie
  • 242 Answers
SOURCE: Dust bag was full and have changed it but not
The extension tube is probably blocked. Check for suction with all the tubes off - if there is suction now then the tubes are blocked - be carefull not to damage them if you poke things in the unblock them.
Posted on Feb 13, 2011
SOURCE: I have a miele S712 (2 yrs old worked fine
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Posted on Jun 20, 2011
Doesn't seem to have much suction when I put my hand under the head. Have cleaned both the filter and the mesh screen
Check the suction from the hose for rge tools see if there is suction
also check to see if there is a obstruction on the short hose to the nozzle
May 16, 2016 | Hoover U5140-900 Widepath Bagged Upright...
I just replaced the bag (used recommended Miele bag). When I turned on the machine the red "bag full" indicator comes on and the suction seems poor. I tried reinserting bag. ?
Good afternoon Kristen.
Vacuum cleaners usually pop the 'bag full' indicator when they lose suction due to the load of dirt in the bag impeding the motor pulling air through.
If you are still getting the indicator with a new bag, and already did the prudent re-seating of the bag, the next thing is likely a clog or blockage elsewhere in the vacuum. You don't specify the model, so I can't be too specific.
Safety first. Please please please make sure the unit is unplugged before you start disassembling.
As you are able, detach hoses, look in the back of the brush unit, see if there's a blockage. Wads of crumpled paper are particularly good at wedging themselves into corrugated flex lines. Depending on location, I've found that a wire coat hanger, bent into marshmallow-roaster configuration, with the old hook bent with some pliers into a long straight section with a small half-loop at the end, can be a good probe for the long sections of tube to see if it runs into anything, and then perhaps hook it and pull it out. Be careful if you do this to not hook the tubing walls and tear them.
Hoping this helps!
D
Nov 18, 2015 | Miele Vacuums
Why does the full bag indicator not work
Usually means there is something blocking the suction (like something stuck in the hose). Try taking the hose off and turning the vac on. If the indicator doesn't go to full now but does when the hose is on, something is in the hose. Usually it's right in the curve of the handle. If your model has a suction relief on it, try opening it up and looking in there. You can also put the hose on the exhaust and try to blow out what is stuck but do this outside as it can get messy.
Aug 17, 2014 | Miele Vacuums
Hoover telios keeps saying bag full when its not
Something is plugged up making it sense there isn't vacuum and saying the bag is full
Jan 31, 2018 | Vacuums
After we change the bag, it still gives us a red light
Greetings,
The bag full indicator on most vacuum cleaners is not completley fool proof. Most vacuums will just register a loss of suction, and they will then illuminate the bag full indicator, whether or not the bag is full.
If you've changed the bag, and the machine is still indicating a full bag, then this could mean one of two things.
1. Dirty Filter. According to the part diagram for your vacuum, there is a filter underneath of the vacuum cleaner bag (Bissell Part Number
203-1013) that is there to protect anything from getting into the motor. Since the filter is located before the motor, most refer to this as a pre-motor filter. Sometimes if this filter is really dirty, it can cause the vacuum to loose suction, which will also cause the bag full indicator to incorrectly display. Simply clean this filter by running it under warm water, then allow it to completely dry before replacing it in the vacuum. While the filter is out of the vacuum you can turn it back on and test to see if the light is off now that the filter is out. If the light goes off, then you have found the problem! If the bag full indicator is still on, please see the next possible problem.
2. Clog In the Vacuum. If the vacuum was run with a full bag, and when you removed the bag, the bag was completely jammed full, then your vacuum cleaner may be clogged somewhere. When the bag is packed full of dirt, the vacuum continues to try and put more and more dirt in the bag, even if it's full. Sometimes the dirt will even start accumulating inside the hose as it has no other place to go. The first place you should check is the hole that you connect the bag to. Remove the new bag that you installed and examine the hole that the bag connects to inside the vacuum. Can you see anything stuck here? If yes, do your best to try and dislodge it. If you're not able to visibly see anything here, your clog may be inside the hose, or even in the base of the vacuum.
If you have another vacuum cleaner this will really help you in clearing the clog. With the other vacuum, take the suction hose of the good vacuum, and connect it to the hose on your Bissell (still while the bag is removed, and the bag housing door is open). When you connect the hose of the other vacuum, can you hear a difference in the motor? Does the motor start running at a higher pitch when it's connected to your Bissell? If yes, then you've narrowed it down to a clog in your hose. If you can feel suction from the other vacuum through the hole that the bag connects onto, and the good vacuum's motor doesn't change noise when connected to the Bissell, then your clog is in the bottom section of the vacuum. You can sometimes stretch out the hose of the Bissell while the other vacuum is attached, and this will dislodge the clog.
If you don't have another vacuum, simply remove the hose from the Bissell completely. I believe that there maybe 2 screws that hold this hose onto the back of your Bissell, simply remove these two screws, and remove the hose. An easy way you can clear clogs is to take the hose outside, and use a water hose that has a pressurized nozzle on it, and spray down the hose while holding the hose of your Bissell vertically to allow gravity to work its magic. You can also stretch out the hose of the Bissell to get maximum benefit of gravity and the water.
If the clog is in the lower part of the vacuum, it is usually right at the suction port behind the roller brush. This is the most narrow part of the vacuums suction intake in the lower part of the vacuum, and is prone to clogs. Simply remove the four screws on the bottom of your Bissell to remove the bottom plate. Look behind the roller brush to where the suction port is to see if you can see any clogged debris.
If this doesn't help clear your clog, or fix the bag full indicator, I'd really like to try and diagnosis this further with you. Please just use the Clarification Request or add a comment and explain what happend after trying these things I mentioned above. I'll be more then happy to try and assist your further. I really hope that this was helpful to you. If you found this helpful, please be kind and rate my repair by clicking the thumbs up icon in the review.
Thank you very much,
Chris J.
Mar 21, 2010 | Bissell 3522 PowerForce Bagged Upright...
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
Keeps showing the bag is full
are you getting suction.check the hose at the end and see if there is suction.is your brush roller turning.no suction will tell it that its full please leave feedback
Mar 20, 2009 | Bissell 3522 PowerForce Bagged Upright...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Lost suction - Hoover Wind Tunnel S3630
You have a clog. The "bag full" indicator is nothing but a vacuum gauge, and impeding the airflow will cause a false indication of a full bag.
Clear your hoses and the air pathways behind the brushroll, and you will be back in business.
-R
Sep 27, 2008 | Vacuums
Miele S514 Solaris Electro Plus Vacuum Logo
35 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
