Question about Heat and Glo GFK-160A Blower Kit for Heat & Glo Fireplaces
Fan working hot air not coming through front vent
No hot air
  • 38 Answers
One, is there any air at all coming through the top vent? If not schedule a professional service call with a local reputable company. You may have a blockage. If there is air coming through and it is cool, try letting the fireplace warm up for about 15 minutes before trying to run the fan. The fan can only blow hot air after the fireplace gets hot.
Posted on Mar 01, 2016
1996 Montero Heater Blower not working
I assume your heater setting is electric control, if so either your defrost and floor heat switch failed or wire problem. For the air not hot, check the heat control valve on the top of the hose it should be in front of the firewall. I don't know your car is using mechanic valve or electric control valve. Anyway check there first. Good luck.
Nov 24, 2013 | 1996 Mitsubishi Montero
My 99 chevrolet monte carlo z34 heat is not that hot and air works for defrost but not dash vents?
check radiator fluid level it take hot radiator fluid to pass through the heater core to produce the heat in your car VIA the fan. also check or replace your thermostat it could be bad and stuck in an open position thus radiator fluid not getting hot, no hot fluid no hot air
the other problem sounds like a duct hose under you dash has come loose locate and reattach.
Apr 30, 2012 | 1999 Chevrolet Monte Carlo
When the oven is on cold air constanly comes out the vents over oven door. Never did that with ild oven. thanks
This is the oven cavity extractor fan. It removes all the hot air from the oven cavity and blows it out the front. When the oven is hot and you turn it off the fan will continue to work until the oven cavity cools down.
Feb 12, 2011 | GE Ovens
Front blower fan stopped working, hot air comes out of the vents when heat is on and going down the road but fan does not work. Rear blower still works but it will not blow out hot air.
There is a thermal fuse inside the air duct. It is located behind the passenger glove compartment. tilt the glove door down and remove and look in. You will see a conector with about 4 to 5 wires. usually held on with two screws remove and inspect. The thermal fuse that runs between the coils will be open. Bypass it at your own risk or buy a new one from dealership or auto wrecker. May meen you fan is running too slow also and not blowing enuf cool air past it.
Jan 13, 2010 | 2004 Chrysler Pacifica
Cool air comes out of the back unit vents and hot in the front
under the dash on the bottom of the heater box there is a little selector motor most likely that motor has gone bad
Aug 07, 2009 | 2000 Ford Expedition
2003 envoy xl fan not blowing air out front vents. But air coming out back vents but its hot
sounds like you have two problems, if there is no air from front then you need to ck power to your blower motor, if no power you need to ck your blower resistor and connector, second if no cool air from rear your compressor may not be engaging, make sure you ck your fuse for the front hvac system.
Jul 29, 2009 | 2003 GMC Envoy
2004 Ford Expedition XLT, front blend door actuator
Hope I was avle to help, glad you up and going.
May 26, 2009 | 2004 Ford Expedition
Hot air comes out of defrost vent at top dash and cold air out of
Hey, what setting is your A/C on Max AC? AC? Cycling air in vehicle or taking it from outside
The car icon on the right in this image is what I'm referring to when I say cycling air in vehicle.
Also, do you ever have cold air blowing? on any setting or any speed? if not, find your A/C fan, it is smaller the the engine cooling fan, sometimes there are 2 fans together. The AC fan should be located at the front of the vehicle and is usually electrically powered.
Also try to find your compressor, looks something like this:
is it running? is one pipe hot and one cold? (the pipes I am referring to are inlet and outlet pipes of the A/C compressor unit.)
Hope this helps, keep me posted
May 10, 2009 | 1994 Mercedes-Benz E-Class
2003 Honda Accord 4 cyl ex Air conditioner Problem
Even under acceleration you should have cold air from vents.Does the air change from the vents to defroster or elsewhere when accelerating? Make sure you have a full charge of refrigerent..Also make sure the engine isnt running hot...
Sep 19, 2008 | 2004 Honda Accord
Heat and Glo GFK-160A Blower Kit for Heat & Glo Fireplaces Logo
Top Heat and Glo Home Experts
Donni Steen
Tom Chichester
Are you a Heat and Glo Home Expert? Answer questions, earn points and help others
