Question about Sharp Televison & Video
I need a code for my Blue Diamond TV, for the URC-3910 remote!
free2rhyme
SOURCE: need code for remote control
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
Posted on Mar 25, 2009
pabloloco
  • 2335 Answers
SOURCE: I.Needs the codes for remote control one for all
I can help you to program your One for All Big Easy URC-3220 Universal Remote for your Sanyo Plasma TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Posted on Apr 11, 2010
joeymille916
  • 143 Answers
SOURCE: i need the code my
http://www.oneforall.com/uploads/support/e04d2cffae9469f511770f5e563d5330.pdf Here is the manual for the remote... the codes for Quasar TV are... 0250, 0051, 0055, 0165
Posted on Oct 10, 2010
  • 8909 Answers
SOURCE: need codes for buch tv
If you contact URC's web site, the information will be there.
Hope that helps.
Posted on Nov 15, 2010
BElectric
  • 1140 Answers
SOURCE: i have a currys essentia
I'd like to be able to give a more positive answer but I don't think this combination of remote and TV will work together. One-for-All do not list codes for Curry's brand devices. These are simply 'badged' TVs from an often unknown manufacturer.
As there are no codes listed for your brand, identifying a code which will work is limited to trying to identify the original manufacturer of the TV and hoping that your TV shares common components with a TV that your remote does have codes for. There are too many codes in the remote to try to guess a code or to try them all using the manual code entry method.
Your best option is to try the Code Search:
1. Switch the TV on.
2. Press the "DVD" button on your One-for-All remote
3. Press and hold the "MAGIC" button on the remote until the red LED under the POWER key flashes once, then twice.
4. Enter 9 9 1 using the number keys on the One-for-All remote
The LED will blink twice again, indicating that the code search is active.
5. Press the "POWER" button on the One-for-All remote
6. Point the remote at your TV and press the "CH+" button slowly and repeatedly until your TV switches off.
7. As soon as (or if) your TV switches off, press the "MAGIC" button again to store the code.
8. Test the remote with the TV for the common functions, i.e. POWER, VOLUME and CHANNELS.
9. If the TV does not respond (or does not respond as you would expect), go back to step 1 and continue the code search . This does not restart the code search from the beginning, it simply picks up from the code that is currently set and continues through the code list.
Please note: There are hundreds of codes stored in the remote so it can sometimes take half an hour or more to search through them all.
Your TV is a DVD combi so this means the correct code should be stored in the code list for DVD players. However, as it is impossible to discover the true identity of your TV, it is also possible that there may be a code that will work with your TV in either the TV or VCR code list. You can try repeating the code search as above, but in step 2, press either the "TV" or "VCR" button instead to run through the codes for these device types.
It is also possible to control some TV/DVD combis by using two codes. Run through the code search in "TV" mode first. If you can find one that will operate the TV functions, store it, then run the code search again in "DVD" mode. You may then find a second code that will operate the common DVD functions, e.g. PLAY, STOP, PAUSE, etc. If this method works, you simply need to remember to press the "TV" or "DVD" button on the remote first - depending on which function you are trying to control.
There is a "pot-luck" element to getting any universal remote to work with any device. There are hundreds (maybe even thousands) of universal remotes and thousands of brand/model combinations of TV. This means there is an almost incalculable number of combinations of TV and universal remote and expecting there to be a code for every device is unrealistic. Unfortunately, this element of luck also increases for devices from a lesser known brand and even more so when the TV is newer than the remote.
Please try the code searches as detailed above. This can require a lot of patience. If you still can't get any response from the TV, then it's unlikely that your particular combination is one of those that will work. You would also be taking the same chance with any other universal remote, even if you bought a new one.
If you can't get any results from the code search, please post back for further assistance.
Regards,
BElectric
Posted on Dec 30, 2010
Pentus TV with missing remote bought an all for one URC-3910 seems to be no listing for pentus tvs help please
Use code search-TV on your remote (One For All) to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Aug 21, 2016 | Televison & Video
I need a code for a blue diamond tv model number BD40DL fev10
Remote Code for Blue Diamond TV - Boards.ie
www.boards.ie > Talk to... > Sky Ireland
Aug 7, 2015 - After checking our database for remote codes we don't have a codeavailable for your particular make of TV, Blue Diamond. I will be sending ...
Horizon UPC Blue Diamond LED Remote Control - boards.ie
www.boards.ie > ... > Cable & Digital TV > Cable & MMDS & IPTV
Dec 11, 2013 - I have bought a BLue Diamond TV and upgraded to UPC Horizon HD. ... the code for Mitsubishi who from what I can see make Blue Diamond Sky Remote COde
May 29, 2015
Anyone code for programming sky remote bluediamond tv?
Dec 10, 2012
More results from www.boards.ie
Dec 10, 2015 | Televison & Video
I need a code for the for the Fussion tv remote control bought URC 3910
0281,0269,0230,0219. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 09, 2015 | Universal Remote Control Televison & Video
How to sink with your tv instructions universal remote urc-3910
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Check associated ads too. Sometimes, it might help you.
May 28, 2012 | One For All URC-4880 Remote Control
Need code for universal remote for dvt diamnond 2170 tv
Manual http://www.rockabilly.net/files/manuals/URC-3605.pdf
Codes http://www.hifi-remote.com/manuals/manual.shtml?URC-3605-codes
But there is no code for DVT Diamond. So you can try 0000 and then let URC learn it.
For example press 1 (to change channel to 1) for 10 second.. and maybe it will learn it. Like on others URC
Or maybe try this Diamond 530, 531, 544 (this is from panasonic)
Jun 14, 2011 | One For All URC-3605 Remote Control
Diamond Vision TV Code
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Diamond Vision TV/DVD combos in the One For All URC-3021 Code List.
But don't give up; many manufacturer's re-use others' control codes. Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
One For All URC-3021 Manual
One For All URC-3021 Code Entry
One For All URC-3021 Reassign Key
May 23, 2010 | One For All URC-3021 Remote Control
Televison & Video Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
