SOURCE: How do I open the
May I ask why you want to replace the power cord? Is it frayed / damaged? If so then just cut it off and attach a new extension to the cord, avoiding opening up the machine. You can get a new end for the cord, or cut the cord short and essentially get a new cord without opening up the machine. Check with a local hardware store for power cord replacements and they will show you all the options. Otherwise let me know why you feel you need to change the cord.
Thanks
Tim
How to Clean SmartGrind Blade Coffee Grinder - White
1. Always unplug the unit before cleaning. Wash the lid in warm, soapy water - not in a dishwasher.
Wipe the grinding bowl, base, and other parts with a slightly damp cloth or sponge. Take special care
around the blades; they are sharp! Dry parts thoroughly. Do not immerse grinding bowl, base or plug
in liquid or under running water.
2. Never use harsh detergents or abrasive cleansers or scouring pads to clean any
part.
3. To remove residue or aromas left behind by nuts, grind one tablespoon of baking
soda in the bowl then wipe thoroughly.
4. Use the built-in cord wrap on the underside of the unit to store the cord
