Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HDTV I have a 47' tv it was working good until we switched cable company's when we did the picture was tripled and the color is off! My question is why is there not a recall on this tv if everyone is having so much problems with it? Please Help!!!
  • 1 more comment
  • Anonymous Nov 26, 2007
    I have the same problem with the same samsung hdtv. It was working fine until the screen showed double and red and green. The tech said it was the stk's. I changed it no change, then the tech said I had to tune the convergence with the remote. bought the service manual for alignment and dont know what all the diagrams mean. I am so fed up with this tv that i will never buy another samsung product for as long as I live.
  • mongo7677 Dec 06, 2007
    Where do you find the convergence instructions?
  • dpav77 Jan 11, 2008
    I have the same problem that theyre talking about. I went through and started to fix thte grid, only to realize that I couldn't move my green left and right, and that my blue and red would not go up and down. Is there any way to troubleshoot this or I am I just SOL??
Good fix, but I have another problem. I can't adjust my blue lines and I can only adjust the vertical green lines. Is this an adjustment in the TV or do I have a bad convergence card?
Posted on Jan 05, 2008
Thank you Thunder!
You made my day.
I have been fretting over the blue and red ghosts for quite some time, had been considering returning the set to the repair shop that I had to take it to after it went haywire like all the others. The shop did a poor job of converging after the repair and I didn't take it back, just lived with it, until now. I just finished going through the process of aligning the grid and looks great.
Merry Christmas to you too.
I do have one question, now the self focus does not want to work, it comes up with a message "check data" or something like that up in the left hand corner. Any suggestions?
Posted on Dec 31, 2007
  • 3 Answers
Turn on the set, let it warm up for 1 hour. Put the cable box or satelite on a 1080i channel so it's on the screen. Press Mute, 1, 8,3 on the remote you'll get the grid.
Red Select is 7 (on the remote)
Green Select is 8
Blue Select is 9
Red Mute is +100 key on the remote
Green Mute is 0 (zero) key on the remote
Blue Mute is PRE-CH key on the remote
Note: these are toggles on and off
Cancel Key is 3 on the remote ( to cancel all changes you've made)
Use the Directional Buttons around the ENTER button to move to another line or segment.
Channel up and down buttons move the lines up and down.
Volume up and down moves the lines left and right.
The goal is to put all of the red, green and blue lines on top of each other to make the grid white.
Save your new settings by pressing Add/Del key found in the slide cover at the bottom of the remote.
Exit convergance by pressing S.MODE button on the remote.
I hope this helps. I'll check back to see if you have any further questions.
Merry Christmas!
Posted on Dec 25, 2007
If you changed the ICs you need to adjust convergence, read carefully the instruction and alingn the lines using remote control commands. Is a long process. My tv loss convergence three times , i will never buy another samsung product. I told every body that i know that never buy another samsung product.
Posted on Nov 29, 2007
Samsung HDTV model HCL4715w1 has horizontal wavy lines in the middle of the screen. Is it worth Fixing? Any solutions to this problem?
Yes,tv screen have R,G,B colors lines mis alingnments,have colors shaded pictures or 3D pictures look aike?Tv have a problems known as convergence pictures problems.The tv convergence board it is dead.This convergence board must require replacement of 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence pictures problems.U have some mechanical skills like take things aparts and putting it back together again?Yes,try website like Tvrepairworld.com to buy a whole refurbish tv convergence board for the replacement.The DLP tvs brands names Samsung and Akai used the same tv convergence board.Or tries those tvs shops will cost u like $300-$350 for parts and labors.
Jun 28, 2011 | Samsung HCL4715W 47" Rear Projection...
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color is horrible basically black and white
Ur tv colors wheel is dead,colors wheel is the problems,must be change.When the tv picture are black&white,colors fade in & out,loud squiling and motor noises.All these problems,indicate the colors wheel it dead,require changing.Hire a tv tech.for this job,because the colors wheel replacement require to take out alots of machanical's parts even able to get to the colors wheel to replace it.
May 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
RCA 52 HDTV Triple iamges in red, blue and green
I had the same problem with my RCA D52W23. I change out the convergence board and the 2nd fuse the one near the flyback. After getting TV back together picture was good except white backgrounds looked washed out with greenest at the edges. I called cable company and they came out fixed my cable line with was dropping and gave me a new HDTV box which was the newest one. That fixed my problems.
Apr 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4252w - yellow tinge on left side of screen
If you put magnet speaker ( Standard speaker) near the TV, first you must move that speaker away from your TV because this will cause your colour TV screen color scattered. Then switch off your TV for 5 hrs. then switch it ON again your problem will be solved if the degaussing coil working.
Jun 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
644 people viewed this question
Jerry Greenberg
Jerry Greenberg
