Question about Whirlpool Washing Machines
Cabrio stuck on sensing with loud humming noise and would not drain
huuum
  • 750 Answers
SOURCE: Cabrio won't drain/spin, loud hum
Hello karlatw
Welcome
It sounds like the motor coupler is broken. Tilt the washer back &look on the floor for rubber or plastic shavings. This would indicatethat the motor coupler has failed. Another possibility would be thetransmission or drive block.
http://www.managemyhome.com/mmh/answers/Answers.action?intcmp=MMHxG_HomexAnswers_
Widget#l4q122032
Unfortunately you need service for this repair!
Please remember to leave a solved rating before you sign off!
Thank You
Posted on Dec 21, 2008
hsanfor
  • 71 Answers
SOURCE: Won't drain
In my case the drain hose was pinched. My machine got pushed up against the hose and I had the same problem with it humming and not draining. I came in here and read some of the replys and watched to see if water was coming out of the drain hose and it was but only a bit. I pulled the machine out to get a better look and sure enough it started working fine.
Posted on Jun 17, 2009
  • 572 Answers
SOURCE: Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Posted on Feb 07, 2010
heatman101
  • 43501 Answers
SOURCE: My Whirlpool Cabrio WTW6200SW1; spin cycle loud roar
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 07, 2010
  • 57 Answers
SOURCE: whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
Posted on May 18, 2010
Washer will not drain. Filter was removed and cleaned. Washer makes humming noise
Most likely there is something stuck in drain pump open the drain pump hose and check if something is stuck there.
Aug 22, 2014 | Washing Machines
Washer will not drain or spin
http://www.fixya.com/support/r4604609-washing_machine_washes_but_wont_drain
Apr 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
1998 VW Cabrio loud humming from what sounds like the transaxle
Have you checked that the noise is not tyre noise?
Interchange the wheels front to rear (or left to right) to see if it has any effect on the noise.
Only do the test below if the car is securely chocked so as not to move, take great care not to contact moving parts!
Securely jack both the car drivewheels off the ground, then 'drive' the vehicle through through the problem drive speed/gears while listening for the noise. If the noise occurs under these circumstances you may be able to further localise the source by listening (very carefully!)with a short hose pipe held to the ear.
Jul 21, 2009 | 1997 Volkswagen Cabrio
Hello karlatw
Welcome
Widget#l4q122032
Thank You
Dec 09, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Dl error will not clear
My Whirlpool cabrio is making a humming noise an the water filled the tub but wont drain i tried pressing buttons but no luck please help,how do i reset it
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
