Need to access the Hard Drive.
SOURCE: I have an HP 513n, currently running Windows XP
Yes. Install the hard-drive, and use Windows XP to "partition" and "format" the second disk-drive.
When installing Windows 7, be sure to "point" the installer to the drive-letter of the second disk-drive.
Windows 7 will create a "dual-boot" environment.
SOURCE: can i format my entire hard drive on my hp iq504
You may have problems with drivers. Hardware is designed and intended for specific Operating Systems. You can chat with the boys at HP and ask them.
Any ide drive. The mainboard does not have a sata connection.
SOURCE: Hard drive from my xp computer, added as external hdd to new windows 7 pc, need to get ' permission
umm xp used a completely different kind of hard drive and may not be compatible with the windows 7 environment I gather you might be trying to import the old data from that xp drive and use it on the new machine, correct? what is model number of new computer if this in fact is the case.
Testimonial: "While my solution was sort of self discovered, another voice in my head helped me think harder. I appreciated the efforts very much."
SOURCE: how to wipe hard drive and clean install windows 7
Sounds like you may have purchased a "Windows 7 upgrade" (whatever version Home/Pro,) version....
now that win7 is on it, you can boot from the CD, choose the "repair my computer" option, then choose the Advanced Startup repair options....and you can use the command window to re-format, or delete the partition and and re-format the drive....then start-over with a clean disk.
article to read on getting it to 'authenticate' if you DID buy Upgrade media and you want to do a clean install, (normally it won't without some tweaking.)
http://www.maximumpc.com/article/howtos/how_use_your_windows_7_upgrade_disk_fresh_pc
Tallon41
