Question about Bose Lifestyle 18 System
Can I connect my lifestyle 18 to a new amp
Only 1 optic out on my lifestyle 18 and I have 4 things to connect to it
4 Suggested Answers
realmacoi
  • 18 Answers
SOURCE: Connect my remote of my bose lifestyle 18 to my samsung 46a 650
Hi, have you tried going to the system settings menu adn program your 3rd party products htrough there? You may try varied IR code settings for your electronics from there and one of those codes should work atleast for your system. There may be some codes you will get to use but does not have all the funcitons so you need to be patient to try them all.
As per the Blue-Ray DVD, the remote code might still not be embedded on the IR controller chip that is installed in your Lifesytle (after you have tried all the codes and still none works). Bose does release regular firmware updates via their user mailer (if you have registered your product online) or you may passby any of the Bose service center and request them to provide you with the update disc specific to your system version (look underneath the DVD player and the bass module they should indicate AV-- and PS-- models).
Glad to be of service...
Posted on Apr 08, 2009
smarthome2
  • 1114 Answers
SOURCE: I am trying to figure out how to connect my blu
Only one can be digital. TV preferably since you probably watch more tv than dvds. use the analog output from the bluray to the analog in on the lifestyle 28 and optical for TV
Posted on May 17, 2009
SOURCE: Connecting PS2 to Bose Lifestyle 18
we use the AUX for our PS2 and it works just fine and use the yellow cord into the video in on the tv, the red and white into the BOSE
Posted on Apr 12, 2010
How do I transfer music from my lifestyle 38 to a newer unit
Suggest you consult with BOSE
My inference from
https://worldwide.bose.com/productsupport/assets/pdf/guides/lifestyle/en/ig_en_ls18_series2_ls28_series2_ls38_series1_ls48_series1.pdf
26241829-avo1hezaf1vg34ez5fnknftc-5-0.png 1. You should be able to backup using the DATA Connect port.
Not sure of the pin configuration and external device.
2. You should be able to connect using Optical-Out port to Optical-In of new device (if it exist)
Jul 20, 2016 | Bose Lifestyle 38 System
How to connect pc to bose lifestyle 38
Method 1 (easy): you'll need to get a 3.5mm to RCA audio cable pictured here: http://www.daydeal.com/files/images3/blk_rca_cable.jpg plug the 3.5mm end into the computer's speaker/headphone jack and the RCA (red&white) end into the lifestyle 38.
Method 2 (harder): You can purchase and install a PC sound card that has an optical out option and also an optical cable. Then you can use the lifestyle optical out jack. This is a digital connection so the sound quality is better and better suited for the 5.1 channel that the Lifestyle 38 has.
Mar 01, 2011 | Televison & Video
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
SA-2 and SA-3 doesnt work together
its alwaays better just to call bose their great when it comes to this
May 20, 2009 | Bose Lifestyle 18 System
I am trying to figure out how to connect my blu ray and HDTV to my Bose lifestyle 28 and also have a HD cable box. The Lifestyle 28 has no HDMI inputs and was purchsed in early 2002. I believe it is a type...
May 17, 2009 | Bose Lifestyle 28 System
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
Connecting lifestyle 27/38 to psp3
Your Bose system doesn't lead sound trough hdmi.
You must connect the optical cable with your lifestyle.
Change the sound connectionsettings in the menu of your ps3.
You also need to assgn the optical connection in the setup menu of the lifesyle. e.g. optical=aux.
Dec 28, 2008 | Bose Lifestyle 28 System
Dec 27, 2008 | Bose Lifestyle 38 System
No sound from rear speakers on the lifestyle 18
The SL2 works in such a way that the speaker satellite out put from the bass modules is fed to the input of the SL2 transmitter (remember, transmitter) then the sattellitespeakers are connected at the other end of the room to the receiver. An initial blinking green light should be seen and once the system is turned on this turns into steady green. Both the SL2 transmitter and receiver operates via WIFI.
Dec 21, 2008 | Bose Lifestyle 18 System
Bose Lifestyle 18 System Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
