Question about Bosch Dishwashers
E15 error code bosch dishwasher - Bosch Dishwashers
4 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: E15 error message making a funny noise, is the a
E15 indicates the anti flood device in the base of the appliance has been activated.
Unplug the appliance.
Take the cover below the door off.
Take the insulation out of the way.
Remove any water in the base that is lifting the float.
Once removed, try the appliance again. Watch through the open inspection panel to see if the appliance is leaking.
If the float isn't up activating the switch then the switch, wiring or control board is faulty. Check the float and check the switch.
Your machine is still under warranty so you do need to be careful about what you do.
Trying to repair it on your own may invalidate the warranty.
Hope helps.
Posted on Apr 27, 2011
SOURCE: My Bosch dishwasher has an
We read on google that a lady had this problem and we copied her instructions to see if it worked and am so pleased to say it did.
OUR PROBLEM WAS WE HAD E15 AND NO WATER IN THE BOTTOM OF OUR DISHWASHER, BUT THE PUMP STILL KEPT GOING ON AND OFF. EVEN WHEN THE ON/OFF BUTTON ON THE DISHWASHER WAS OFF.WE PULLED THE DISHWASHER OUT AND TILTED IT BACKWARDS (WHILST STILL ON), AND AFTER A MINUTE THE SETTING RETURNED TO NORMAL.So do try this before you call an engineer.
Posted on Oct 22, 2011
SOURCE: I have a bosch dishwash e15 check water
I found this solution on elsewhere on fixya. it relates to a little float switch designed to detect water leaks I think. 1. turn off power and water 2. tilt back machine about 45% (have towels ready to soak up any spill off 3. when all the water has emptied, right machine and retry. if the problem keeps reoccurring, you may have a genuine water leak. I had to try a few times but this worked for me and saved me at least 4 days of hand washing over a long weekend. good luck
Posted on Oct 27, 2011
I have a Bosch dishwasher with a E15 error. This is triggered when the basin overflows due to the water not turning off during the fill cycle, overfilling the basin. E15 turns off the water filling.
There must be a bad switch on the water level float; if it were the valve, turning off the valve via the overflow switch wouldn't stop it either.
Apr 14, 2018 | Bosch Dishwashers
Error 15 in BOSCH dishwasher model sms69m18gc
E15 error code indicates that there is water sitting in the base of the dishwasher.
Most common reasons:
  • malfunction of the water drainage sensor when the aqua-stop worked
  • the system is clogged
Mar 11, 2018 | Bosch Washing Machines
Bosch dishwasher shows an error message E15. Any suggestions on how to resolve the issue. We've cleared the E15 several times by tilting unit and removing water, but seems to reappear
E15 is a leak into dishwasher base. Leak can be as simple as using to much soap powder or a split lower spray arm to more expensive fix of a leaking sump base or wash pump. Need to pull dishwasher out of cavity, remove side panels and front kick panel and run machine and watch base to see where leak is coming from. Have had them leak from 4 main places. Heat exchanger where large plastic nut screws from inside. Bottom of wash pump. Plastic sump base (mainly towards front of machine. And last place is a small pin hole can develop in stainless base of machine towards front of dishwasher. Check soap usage and lower spray arm for splits first.
Dec 29, 2017 | Bosch Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
I have a bosch dish washer with a E15 error and warning light to check water flow
E15 fault is water into base and has activated the anti flooding device.
You will need to remove the water from base and investigate for leaks.
Jul 10, 2014 | Bosch 24 in. SGS43C12 Classixx...
Error code e15
The E15 error message specifically indicates that there is a flood issue on the unit. This usually happens when the bottom part of the unit becomes flooded with water.
STEP 2
If this happens, there is a possibility of a leakage somewhere in the system. This occurs mostly on the drainage system of the unit where the water passes through different hoses pipes before finally releasing the water to the sewage. STEP 3
This problem can be solved by inspection. Remove the unit and take off the cover. Drain all the water and look for the source of the leakage.
Mar 04, 2014 | Bosch SGE63E15UC 24 In. Stainless Steel...
Alarm e15 up and can't reset
Bosch SMS Series Dishwasher Fault Codes E15
Water in base
Float sensor in the base has been activated. You can try to empty the base and restart the dishwasher as you will find noted many times in the forums but, if there is a leak this error code will simply be displayed again, you must find the cause of the leak.
but if you have a different model it can be something else
Dec 26, 2013 | Bosch Dishwashers
Code E15 bosch super silence dishwasher
Use dish washing rug and soak water out trough salt inlet. Only 10 degrees tilt needed. Boch Super Silent dishwasher. E15 error code.
Mar 02, 2013 | Dishwashers
The control panel on my dishwasher is showing a tap and E15
Mine's a bosch, same problem but started with E25 due to broken glass in the pump impeller, after struggling to remove it and then testing, it eventually moved to E15 as rightly so, no water was entering the machine due to the E25 code. The advice above is good, but take the device out first and tip the machine. This cured my faults without the need for a service call or spare parts.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
22 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
